Rocker arm studs
Old Feb 4, 2011 | 08:38 PM
qws's Avatar
qws
Default Rocker arm studs
Quick question. On my build I'm changing out the stock 3/8" rocker arms to the 7/16". Anyways is there a torque spec for the new studs or can I just assume its the same as what the FSM says.
thanks
Old Feb 4, 2011 | 09:00 PM
John A. Marker's Avatar
John A. Marker
AFR uses 60 pounds of torque on their studs, it should be about the same for yours.
Old Feb 5, 2011 | 02:01 AM
rpoL98's Avatar
rpoL98
i replaced the GM 3/8" rocker studs on my 113 heads with ARP 234-7202 (typical SBC applicaton) 7/16" rocker studs. ARP instructions call for 55ft-lbs with moly lube, 70ft-lbs with 30wt motor oil.
Old Feb 19, 2011 | 03:14 PM
A95Y's Avatar
A95Y
Did you use guideplates with these studs?
Old Feb 19, 2011 | 05:27 PM
rpoL98's Avatar
rpoL98
yes, i replaced the GM "assembly aid" pushrod-holder plates with normal SBC guideplates. i also replaced the pushrods with hardened ones. and while i was at it, i installed roller rockers, non-self-aligning regular wide-body (i.e. not narrow-body). actually, the latter was the objective.
To Rocker arm studs
