headlights wont fully close, need help.
Old Feb 8, 2011 | 05:30 PM
cwyates4's Avatar
cwyates4
Default headlights wont fully close, need help.
Here's the rundown. I just put the newer style 88-up headlight assemblies on my 84. They run just fine, but neither lamp closes 100%. They lack an inch at most. Any ideas??
Old Feb 8, 2011 | 06:34 PM
Tom 35th anniversary's Avatar
Check the rubber adjustable stops, they may need readjusted. Also look fo any interference.
Old Feb 8, 2011 | 07:42 PM
oldalaskaman's Avatar
oldalaskaman
manually adjust both of them till they are all the way open and firm on the stops, if that doesnt put them full open , then adjust the stops
Old Feb 18, 2011 | 03:45 PM
cwyates4's Avatar
cwyates4
neither of the above answers worked.....I could adjust the stops, but that wouldn't do any good. they would still not completely close. I cant even completely close them by hand. They roll perfectly, open fully, make no noises....they just don't finish the close 100%. The drivers side is the worst of the two, it misses closing by a little over 1/2 inch. The passenger side is about a 1/4 inch.
Are there any good ways to adjust them??
Old Feb 18, 2011 | 03:58 PM
oldalaskaman
will they adjust all the way closed with the manual ***'s?
Old Feb 18, 2011 | 04:27 PM
cwyates4's Avatar
cwyates4
the ***** get VERY tight, I've turned them both until I cannot turn them without mechanical advantage (channel locks), and they still fail to close. they are freshly rebuilt, I'm almost tempted to see if channel locks wont do the trick...
To headlights wont fully close, need help.
