plenum and runners?
Old Apr 11, 2002 | 08:46 PM
siberianhusky911's Avatar
siberianhusky911
Default plenum and runners?
Is the inside of the plenem and runners supposed to be clean i took mine off and they are all black inside almost like oil. Is this bad or is this normal? I tried to wipe them done but its tough to get in there. Could this cause any problems if there real dirty? thanks Ron
Old Apr 11, 2002 | 08:48 PM
Corvette0096's Avatar
Corvette0096
Default Re: plenum and runners? (siberianhusky911)
Just took mine a couple hours ago and they to are black. how did you get the torks bolt off on drivers side by the wiper box?
Old Apr 11, 2002 | 08:56 PM
vader86's Avatar
vader86
its carbon deposits, and it can hurt airflow (hp), but you could take it off and try to clean it a little
Old Apr 11, 2002 | 09:00 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's normal; due to the EGR exhaust gas feedback.
I took my used base to a local engine builder and had it hot sprayed for $30. It came out very nice and much easier than doing it with carb cleaner as I use on the runners.
One metod I've used on the runners is to spray 1/2 a Scotch Brite pad with carb cleaner and use a section of 3/4" heater hose to pass it through each runner, several times. I finish up with carb cleaner on paper towls.
Unless you have a solvent tank, having someone clean em up is much easier and, to me worth the few $$.
The problems arise when the EGR valve carbon's up and sticks or you get buildup in the TB and on the throttle plates and in the IAC bore. Buildup in the plenum, runners & base isn't usually a problem, but do you realy want to put those dirty pieces back onto your motor??:eek:
Old Apr 11, 2002 | 09:03 PM
Corvette0096
Default Re: plenum and runners? (65Z01)
65Z01. If you dont use the egr the intake and heads will be clean?
Old Apr 11, 2002 | 09:20 PM
65Z01's Avatar
65Z01
Default Re: plenum and runners? (corvette0096)
Oops, my bad. I foregot about the PCV on the left and the breather feedback on the right. I guess these two may be causing the oily film.
Old Apr 11, 2002 | 09:57 PM
vader86's Avatar
vader86
For the most part, if you remove EGR and PCV they will be.
To plenum and runners?
