Fuel Pressure Regulator Install Tips
Old Feb 9, 2011 | 03:38 PM
GS348's Avatar
GS348
Default Fuel Pressure Regulator Install Tips
Just purchased a FPR for the car and although it should be a straight forward install I wanted to double check here first for any insight/recommendations or possibly and do's and dont's.
Any suggestions are greatly appreciated....time to buy some service manuals now that the car is getting slowly up there in age.
Old Feb 9, 2011 | 03:41 PM
Sandpiper59's Avatar
Sandpiper59
Nothing special when I had mine off, but it's worth triple checking your work as you go simply because you'd have to pull the plenum again for even a minor leak..
Old Feb 9, 2011 | 04:14 PM
Aardwolf's Avatar
Aardwolf
Check things over! Might want to add thread sealer/locker. Check for burrs where they drilled the vacuum hole.
Old Feb 9, 2011 | 06:48 PM
WW7's Avatar
WW7
This is very important, turn the key on and power the fuel pump to make sure you don't have leaks... Also if the diaphram is older it might be a good idea to replace that while your at it. TPIS has the best price that I have found on these at around $39.00..WW
Old Feb 9, 2011 | 07:20 PM
JackDidley's Avatar
JackDidley
No plenum to pull on the LT4. Very straight forward job.
Old Feb 9, 2011 | 07:25 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Not on his GS
Just have to remove the plastic fuel rail cover.
Old Feb 9, 2011 | 08:29 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Let me know if you need pictures posted. I'm going to take some of the car with the new 383 this weekend.
Old Feb 9, 2011 | 10:13 PM
GS348's Avatar
GS348
Default This is very helpful Guys....
Originally Posted by RollaMo-LT4
Not on his GS
Really appreciate this.....any sealer necessary?
Old Feb 9, 2011 | 10:14 PM
GS348's Avatar
GS348
Default Thanks
Couldn't hurt.....this is a new one for me. Thanks
Old Feb 9, 2011 | 10:32 PM
redrose's Avatar
redrose
1) relieve pressure in the rails before removing fpr...pull fuel pump fuse and 'run till quit' then wrap shop rag over shrader (test) port and depress shrader core to bleed any residual pressure...immediately remove gasoline soaked shop rag to safe area outdoors.
2) lightly lube '0' rings on new fpr with clean motor oil before install.
3) test for ZERO leaks by turning key on/off several times before cranking/starting engine.
Old Feb 9, 2011 | 10:50 PM
RollaMo-LT4
No sealant, just two o-rings.
Old Feb 10, 2011 | 08:06 AM
GS348's Avatar
GS348
Default Big Thank You
Perfect....thanks so much; extremely helpful
To Fuel Pressure Regulator Install Tips
