Please help !! Please help !!!
Old Feb 12, 2011 | 12:48 AM
NASSTY SS's Avatar
NASSTY SS
Default Please help !! Please help !!!
Is my 1994 obd1 or obd2 ? I replaced the IAC,MAT,& MAP ! Service engine light still on ! Replacing EGR 2mrrow ! With obd2 scanner no codes come up !! Thanks 4 the help !!
Old Feb 12, 2011 | 12:52 AM
Doughboy2k3's Avatar
Doughboy2k3
http://www.corvettephotographs.com/ecm.html
looks like obd1 with a 16 pin connector. Thats what I found on the link.
Old Feb 12, 2011 | 01:14 AM
NASSTY SS's Avatar
NASSTY SS
Thanks !!
Old Feb 12, 2011 | 04:55 PM
davenbocafl's Avatar
davenbocafl
dont you have to reset the light regardless of what part you replace?
Old Feb 13, 2011 | 07:56 PM
jfb's Avatar
jfb
Blindly replacing parts is about the dumbest and most expensive way to repair a car. There must be stored error code/s if your SES light is on and the stored codes will tell you where to start doing your diagnosis and the GM repair manual will have the diagnostic procedure. Get a scan or a scanner and a GM repair manual and use it.
Old Feb 13, 2011 | 08:22 PM
rodj's Avatar
rodj
Originally Posted by jfb
Blindly replacing parts is about the dumbest and most expensive way to repair a car. the stored codes will tell you where to start doing your diagnosis . Get a scan or a scanner :
Even a paperclip will get you better results than guessing
Read
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Feb 13, 2011 | 08:55 PM
NASSTY SS's Avatar
NASSTY SS
Thanks ! The reason i replaced those part's was i wanted new parts & i can afford 2 !!! The car has 1003558 miles on it !! Code 36 came up !! opti time ! Going 2 replace the water pump 2 !! Hope it ain't a DUMB idea !! Thanks 4 your input !!!
Old Feb 13, 2011 | 11:13 PM
NASSTY SS's Avatar
NASSTY SS
Read
Thanks 4 ur help !!
To Please help !! Please help !!!
