Do you think 92 octane gas will work?
Be even better if it is non-oxygenated gasoline. No corn alcohol.
Dont know what these gas stations sell anymore.
You are great at tuning. Follwed you in scan an tune.
May have to retune slightly for that 92 gas.
Let us know.
BR
I guess I'll just have to put some 92 in and see how it goes..Thanks again...Last edited by WW7; Feb 14, 2011 at 08:41 AM.
Like the guys said, the KS is there to adjust.
BTW: We have the same SCR (though my DCR is probably higher). I was hoping I could run mid-grade if I ever had to. (It's why I lowered my initial compression from 10.75:1 to 10.25.)
If you are able to keep your temps way down and keep you air fuel ratio at a nice safe area (mid to high 12s), I would feel ok with as much as 8.5:1 dcr. Personally 8:1 dcr for a street car is more desirable.
My current set up is 8.32:1 dcr and I have to be careful. That is why I am investigating a switch to e85.
I would talk to Pete and see what he recommends.
timing and fueling for knock events.
your tune is off.
I can tune for regular, mid and super....
you are talking about pinging right?
..Im at around 2000 ft above sea level..I would have asked Pete K this question but the guy works 80 hours a week and isn't home to much , I really hate to bother him if I can bother someone else. I figured you guys would know this, and I was correct .Im still in the process of tuning so I guess Mick (mseven) can compensate for any differences the lower octane might create..Thanks for all the info, it sounds like 92 oct will work for me...WW
Chad, I agree dynamic compression is important, but there are many additional factors to detonation, like:
1) DCR (some people refer to SCR and cam size on this one)
2) Outside Temps
3) CC shape and quench size (also remove sharp edges)
4) Engine Temps
5) Engine Load
6) Timing curves
7) ESC circuit condition (and ignition condition)
8) Knock sensor sensitity (for example, how tight installed)
9) Accuracy of octane rating
10) Level of additives/quality of fuel
11) Exhaust configuration/condition
These are only the items I know of. That's why it can vary so much from motor to motor.
Here's the table for max timing retard on an 89 bin (while in PE). Think of this as at or near WOT runs.
RPMS..Degrees
6400 --- 8°
5600 --- 8°
4800 --- 8°
4000 --- 12°
3200 --- 15°
2400 --- 11°
1600 --- 9°
0800 --- 8°
Here's the table for non-PE...
LV8..Degrees
256 --- 20°
224 --- 20°
192 --- 20°
160 --- 20°
128 --- 6°
094 --- 6°
064 --- 6°
032 --- 6°
LV8 is it's name for how much load the engine is under. Consider the measurements noted as 1/8th increments from idle to WOT (though it's a hair more complicated).
Notice, there is quite a bit of headroom here. Still, most tuners wouldn't want you pulling timing all day long. Theoretically, you'd have to drop quite a bit more than one octane point to cause major issues though.
2) Outside Temps
4) Engine Temps
5) Engine Load
6) Timing curves
Gregg,
Totally agree. DCR is not the only consideration, just a rule of thumb and more pertinent than static comp.
Ya, your just a jaunt down K-10 from me
. I need to make it up to KCIR this spring for some TT on Wed. nights.
RPMS..Degrees
6400 --- 8°
5600 --- 8°
4800 --- 8°
4000 --- 12°
3200 --- 15°
2400 --- 11°
1600 --- 9°
0800 --- 8°
LV8..Degrees
256 --- 20°
224 --- 20°
192 --- 20°
160 --- 20°
128 --- 6°
094 --- 6°
064 --- 6°
032 --- 6°
I have been experimenting with all 3 grades of gas on m y last 3 tankfuls, I am back to 91, and pulled a little timing in some areas and hit maf 4,5,6, again.
you can get a bad tank of gas it is possible and that where the knock sensor comes into play to save you $10k motor
besides it's got forged piston and quality AFR heads, it will take a few knocks.
email me your bin file lets see what you got in there...
