Headers are glowing???
Old Feb 15, 2011 | 08:46 PM
hz900's Avatar
hz900
Default Headers are glowing???
91, 383 with long tube ceramic coated headers.
Just took the my car out of hibernation since it has started to warm up here a bit and noticed that the headers were glowing slightly. This was at night so when I openned the hood it was dark obviously and I could see 7 of the eight glowing slightly. This is after it had been idling for only 5 minutes or so. The engine was not even up to temp yet. Is this normal on this type of set up? I've never noticed it before, but I don't think I've ever openned the hood up in the dark either (I had a flashlight I just wanted to look around to make sure everything was working properly).
Old Feb 15, 2011 | 08:52 PM
tehcarguy's Avatar
tehcarguy
It is probably running very lean. Check your fuel pressure. Don't run the engine too long for like that, you could start burning valves and other parts of the engine.
Old Feb 15, 2011 | 09:14 PM
THE 383 admiral's Avatar
THE 383 admiral
are you sure the timing is set correct 6 factory I would run @ 8
stock inj???? if they are 383 needs more Inj <> as above check FP
stock FPR or ADJ
are you sure the FPR diagram is not torn....
Old Feb 15, 2011 | 09:24 PM
tpi 421 vette's Avatar
tpi 421 vette
Actually, I have seen engines that are way rich do that, caused by fuel in the headers give a afterburn effect. Lean will make your engine run hotter, but the glowing exhaust is from the afterburn effect.
When I was dealing with chips on one of my 421's, I saw my car do that when it was dark, and it was pig rich.
Old Feb 15, 2011 | 09:34 PM
hz900's Avatar
hz900
PCMforless did the tune. I've always thought it was a little rich because of the slight smell of fuel when it wasn't warmed up. I never had it dyno tuned because there is no one that does that around here. 5 hours away is the closest place.
Old Feb 15, 2011 | 10:15 PM
383vett's Avatar
383vett
When I run my 406 at a fast idle (2500rpm) for 30 seconds or so, my headers will start to turn red and after a minute will turn bright red. Probably a combination of late timing and too much fuel at that fuel cell. I don't do it often so I haven't spent any time worrying about it or tuning it out. It doesn't hurt anything but it can melt things close to the headers. Willie
Old Feb 15, 2011 | 10:42 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Besides being rich, I've also seen reports of glowing headers that was due to the timing being retarded. By not sending the spark soon enough, the fuel is still burning as the exhaust valves open up. This could be caused by having the dizzy off it's mark or a mistake in the bin.
Interesting that one of the eight isn't glowing though....
How is it running? Power? Have you run a scan to show anyone -- in lieu of a dyno run?
Old Feb 15, 2011 | 10:49 PM
rv34's Avatar
rv34
Do you have any running problems?
When my last opti went it was missing, so by the time I made it home the down pipe was red hot from the fuel in the exhaust igniting.
Old Feb 15, 2011 | 10:56 PM
tpi 421 vette
And one other thing, if it's lean at idle, it will idle poor, and the engine will try to die.
Old Feb 15, 2011 | 11:06 PM
87 vette 81 big girl's Avatar
If You have JET HOT COATED CERAMIC STYLE HEADERS,
Dont let them glow Cherry Red too Long.
You will discolor or even worse blister the coating.
It can be polished out but only to a certain degree.
Running an engine at high idle above 2,000 rpm's in a driveway will turn most any exaughst system cherry red and even the catalytic converters if intact in just a few minutes.
There is no usual road driving speeds of airflow over any of the exaughst system.
So it overheats just as if the ignition timing is way retarded from where it has to be.
Or as if the engine is running extremely lean on fuel delivery.
BR
Old Feb 15, 2011 | 11:18 PM
Engines on a water brake dyno like a Superflow with the engine pulling hard
to get dyno numbers from 2,000 to 7,000 RPM's plus will also make
exahust headers glow bright Cherry Red.
Especially if the shop lights are turned off.
Had a Pontiac 455 dynoed years ago.
The Hooker Super Competition exahust headers glowed like they were going to melt off.
After 15 back to back dyno pulls.
BSFC numbers were right on too along with ignition timing lead.
The headers never melted off. Was concerned at the time though.
BR
Old Feb 15, 2011 | 11:30 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Isn't it a bit early to diagnose a bad tune?
Cars been parked for the winter and was only idling for 5 minutes.
Didn't get up to running temp so most likely its still in open loop.
I'd take it for an easy ride and wait until operating temp is reached.
Old Feb 16, 2011 | 11:10 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by hz900
Just took the my car out of hibernation...
All of the above CAN cause glowing headers at idle. Too rich, too lean, overly retarded timing...and one other thing; a restriction in the exhaust will do it too. It's been sitting a while?
Also, you are in NO danger of "burning valves and other parts of the engine" when idling, regardless of how lean it is. Just not enough energy in that thin mix and not enough heat at that slow cycle speed.
Old Feb 16, 2011 | 11:19 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Start off simple, did you check timing? Did you re-connect the ESC?
Old Feb 16, 2011 | 12:16 PM
hz900's Avatar
hz900
I'm going to borrow a timing light to check and re-set the timing. I'm thinking that is the optimal place to start, especially since as my other thread states I was also having idling issues. I did adjust the distributor a little to see if it would help the idle. I put it back where it was but I could be just slightly off.
After that I think I will finally get the tune dialed in. It was close from PCMforless, but I've always thought it wasn't quite perfect. I've got the cord to hook to a laptop, but that laptop I used is long gone so I'll have to download a program to read it again. Any suggestions.
Old Feb 16, 2011 | 12:20 PM
STEVEN13's Avatar
STEVEN13
Hi,
On my 92 the FPR went bad and was sucking raw fuel. Although my headers did not glow-one of the cats did.
Good luck!
Steve
cv67's Avatar
cv67
St. Jude Donor '05
Youre last two sentences give you the answer
Old Feb 16, 2011 | 04:03 PM
aklim's Avatar
aklim
I had that once and what it was will shock you. Injector fuse blew and one bank was lean. Left bank. So the ECM dumped fuel into all of it which made the right bank super rich and glowed the headers
To Headers are glowing???
