A Question for the ZF crowd...
Old Apr 12, 2002 | 12:09 PM
T1Kilr's Avatar
T1Kilr
Default A Question for the ZF crowd...
When shifting from 1st to 2nd at or above 4000 rpm I wind up grinding the shift. It doesn't matter if I pause or not. But it only happens in 2nd at that rpm. Any ideas? BTW.. stock shifter, orig. clutch(I believe) and 52k miles.
:confused: :confused:
Old Apr 12, 2002 | 12:24 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: A Question for the ZF crowd... (T1Kilr)
It sounds like the Syncs are a little loose... it doesn't seem to happen in mine but I either shift at 1500 or 5500 :D
Old Apr 12, 2002 | 01:37 PM
T1Kilr's Avatar
T1Kilr
Default Re: A Question for the ZF crowd... (92Shawnster)
thanks,Shawnster thats what i'm leaning twards but I thought I would post it to the forum and see what would turn up.. anyone else have other ideas?
:confused:
Old Apr 12, 2002 | 01:40 PM
Bat Man's Avatar
Bat Man
When I am in first and dont go above 3k, cags will come on, If I try to pull it out of 1st it will grind.
If i push in clutch for a second or to the "1st to 4" light goes off, and I can shift into second.
Old Apr 12, 2002 | 01:47 PM
Bat Man's Avatar
Bat Man
Shawn our cars are twins!!!
Old Apr 12, 2002 | 02:10 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
Default Re: A Question for the ZF crowd... (MarkU)
My second gear syncro went out a few years ago from drag racing at the strip. (actually, it was my fault on the strip) But anyway, I could shift into second at any RPM when rolling without the grind.
But don't let this go too long. You'll end up screwing up more than just the syncros. And internal parts for the ZF aren't cheap.
Check out http://www.zfdoc.com or http://www.whiteracingproducts.com both deal with ZF-6 rebuilds and they are both good companies.
Ed
[Modified by fastzr1, 1:12 PM 4/12/2002]
To A Question for the ZF crowd...
