454 help
Old Feb 22, 2011 | 05:52 AM
hamburgler911's Avatar
hamburgler911
5th Gear
Default 454 help
I'm looking at getting a 454 for my '92 C4 this next coming week. I found one thats just been rebuilt for $3500. My concern is that the 4L60-E transmission wont be able to take it. Does anyone know anything that might put my mind at ease?
Old Feb 22, 2011 | 06:55 AM
87 vette 81 big girl's Avatar
Professional quality built 4L60E............many that others buy here on C4 for $3000-5000.00 are junk when real power is put through them.
I built my own 4L60- 700R4, the predessor to the 4L60E.
I am very versed with both transmissions now.
There is another guy here, Pete K. Very good with them also, has a few more years of building them than I do........actually many. Hes just about the final word here on A4 trans here on C4.
If that 454 makes more than 650 Hp, probably best considering a 4L80E transmission. A Big Block Engine like a 454 ci makes so much torque.
I am interested in what they use in the C6's since 2006.
The 6L80E trans, from my own readings, they help the C6 Be Fast also.
Less engine RPM drops between gear changes.
But the transmission is in the rear of a C6 bolted directly to the rear diff.
Myself,
I am only interested in the C6 Vette Auto trans, not the current Chevy truck trans.
Brian
Old Feb 22, 2011 | 07:32 AM
rodj's Avatar
rodj
http://www.joby.se/corvette/mods/2004-12-26_4l80/
It's called a transaxle
Old Feb 22, 2011 | 09:42 AM
yedister's Avatar
yedister
A 200R4 can be built to handle 900 horsepower
Old Feb 22, 2011 | 10:20 AM
WW7's Avatar
WW7
Brian is correct, Pete K is the one to answer you questions on tranmissions. He has been building racing transmissions for many years for many different power levels.....WW
Old Feb 22, 2011 | 10:43 PM
redrose's Avatar
redrose
454 makes 100 ft-lb more torque than a typ 350...4l60e will need heavy $ rework to survive...your D36 rear axle also won't play long under the extra loading...'gumball' tires will hasten failures intensely at both locations.
Old Feb 22, 2011 | 11:02 PM
It can be done.............
Build up a Very Tough 700R4 or 4L60E trans. Take a moderate HP Chevy Big Block 400- 650HP if not drag raced for every second of its life.
I did it with help from Pete K, Dana @ Probuilt transmissions, and others.
Not the easiest of tasks.
Takes patience, know how, correct assembly tools help much, Key
correct parts depending on exact usage intentions, and a budget finalized within your reach and affordability.
Not every trans builder likes to disclose all also.
Brian
Old Feb 22, 2011 | 11:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
You can build one, even a 700r to hold up to a Big block, sounds like a heck of a lot of fun, nothing like the sound or the huge torque they make.
Old Feb 22, 2011 | 11:21 PM
Big Block Chevy's built up and installed into any Corvette with lots of torque and HP can be fun and a scary ride at times on the street.
Kind of power that flattens your eyeballs and sucks your ribcage and lungs deep into your chest.
If you don't believe Jesus or the Lord..............
You just might afterwards.
Especially riding shotgun- Copilot.
Brian
Old Feb 23, 2011 | 01:10 AM
hamburgler911
5th Gear
Thank u guys for the depots and tips! I'll definitely look into Pete k!
Old Feb 23, 2011 | 05:41 AM
93 ragtop's Avatar
93 ragtop
Can you tell us anything about the 454. ie: specs? Make sure that you have the correct linkage for the TV cable. IMO you are going to be having way more problems with the dana 36 then you will the transmission, assuming both are in good condition and stock.
Old Feb 23, 2011 | 05:30 PM
illenema's Avatar
illenema
Brian
Just What Im after, as We here have a 84 Minus engine and trans, Everything else is there.
Old Feb 24, 2011 | 02:45 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
& he is a master craftsman.
Old Feb 24, 2011 | 05:37 PM
383vett's Avatar
383vett
I have a friend with an 89 Callaway and a 4L80e. The conversion was done by Art Carr Decades age for drag racing. Someone in San Diego (I believe) makes a tailshaft to adapt to the c-beam. He's using a stand alone computer. The setup is strong enough to torch a few 44's.
Old Feb 25, 2011 | 12:31 PM
hamburgler911
5th Gear
That's perfect! I live in SD. Thank u. I'll check that out
Old Feb 25, 2011 | 12:52 PM
yedister's Avatar
yedister
Check out the link below,
http://www.transmissioncenter.net/4L...4L80E_Swap.htm
scroll down until you see " Attention C4 Corvette Owners C4 Corvette 700R4 / 4L60E to 4L80E Conversion Kit" it is that section
Old Feb 25, 2011 | 02:50 PM
chad89's Avatar
chad89
I used the PATC tailshaft and output shaft "kit" when I built my 4l80e. It worked but did take a bit of modification of the c-beam to work (had to grind a bit of the c-beam for clearance).
I didn't want to use a stand alone computer, so I used TCI's manual reverse valve body with transbrake. I love it for my application, but I would not use it if you auto x or road race. It does not have engine braking in 1st, 2nd or O/D. I also installed a TCI outlaw shifter in the console which makes driving the RMVB second nature quickly.
For a converter I used a Circle D 245mm Stage III. It is one sweet converter, super drivable and tough, 100 sq. inches of clutch material for WOT lock-up. The Valve body I have now only locks up in O/D, I have been meaning to call TCI to see if I can wire it for lock-up in other gears.
Overall this is the best thing I have done to my car thus far. That said, it defiantly is not for everyone or for every application.
To 454 help
Old Feb 25, 2011 | 03:55 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wondering if you should check with the state smog ref to see what standard they might want that BB to comform to meaning equiptment, type of efi or if allowed period being as youre in Kalifornia
Street or track car?
Old Feb 25, 2011 | 04:34 PM
383vett's Avatar
383vett
Absolutely no way to pass smog with a big block in a 92 in California (legally).
Old Feb 26, 2011 | 11:06 PM
hamburgler911
5th Gear
It's just for street (it's actually my daily driver). I went to the machine shop today tho and asked about getting it to pass smog and they quoted me for $9000!!!! Excluding labor!!! So I may have to got with a 383...or find another machine shop
