A better coolant?
Old Apr 12, 2002 | 09:45 PM
aqua80's Avatar
aqua80
Default A better coolant?
Greeting from the land of the C3's. I thought I would post this question to you high tech C4 guys. Thanks in advance. Has anyone used or know about the non-aquius coolant made by evans http://www.evanscooling.com. It's supposed to run at almost zero internal pressure with a higher boil point than the green or orange stuff.
Old Apr 12, 2002 | 09:58 PM
Rob90's Avatar
Rob90
Default Re: A better coolant? (aqua80)
There was an article in GM high performance about it. They used it in there 396 project. I think there is some special things you have to do before U can use it. When I get off duty I can scan it for ya andv E-mail it
Old Apr 12, 2002 | 10:26 PM
aqua80's Avatar
aqua80
Default Re: A better coolant? (Rob90)
That would be great, this is one of those things that is not a cheap switch over. I wan't to be sure it's not a modern day snake oil.
To A better coolant?
