No start need help
Old Feb 24, 2011 | 11:43 AM
Blame's Avatar
Blame
Default No start need help
Every now and then my vette will not start. Everything will come on radio,fuel pump, dash, and so on. But, the starter will not turn her over. But if I wait an hour or more and try again it will start.
I have a 1990 L98 6speed. Could it be the starter, computer, VAT, or injectior?
The starter itself was the problem.
Old Feb 24, 2011 | 11:44 AM
Blame's Avatar
Blame
it does it if it been driven or not.
Old Feb 24, 2011 | 01:09 PM
THE 383 admiral's Avatar
THE 383 admiral
sounds like the typical starter solenoid is going
clean the contacts on the battery and starter first
Old Feb 24, 2011 | 03:40 PM
pmihaltian's Avatar
pmihaltian
Slingshot
1.) Starter or solenoid;
2.) Battery connections;
3.) Ignition key tumblers worn;
4.) Weak or worn ignitiion key resister.
Let us know what you ultimately discover.
Old Feb 24, 2011 | 04:11 PM
sdennis21's Avatar
sdennis21
6th Gear
Mine was doing the same thing. Put a new starter in two weeks ago and no problems since.
Old Feb 24, 2011 | 04:40 PM
84vette96's Avatar
84vette96
If it only happens after driving and the engine is still hot the starter may be shot. The heat from the exhaust can cause the starter to stop working. I have seen heat wraps to prevent this problem but have only had one starter go bad in over 12 years so never tried one.
Old Feb 24, 2011 | 05:35 PM
Muffin's Avatar
Muffin
Most likely the solenoid, not the starter motor itself. Very common in the SBC.
Old Feb 24, 2011 | 08:21 PM
Blame's Avatar
Blame
Ok with a drum roll please.
The item to blame is the new starter that is not even a year old put on but Shamco (aamco). So in the morning Ill see if it a bad wire, or worn part.
I'll keep you all updated.
Old Feb 24, 2011 | 10:44 PM
jfb's Avatar
jfb
Can you hear the starter soleoid click? You might also have a VATS problem.
Old Feb 24, 2011 | 11:45 PM
Blame's Avatar
Blame
No Im 100% sure it the Starter.
Old Feb 25, 2011 | 11:36 PM
jfb's Avatar
jfb
Why are you so sure, you have no diagnostic evidence its the starter. In fact the evidence you have is that VATS is likely the cause of your no starts. When it won't crank, unplug the clutch safety switch and install a jumper across the socket. You should have 12v on the jumper with the ign in crank position. If no 12v, then pull the kick panel above the drivers feet and find the 2 wires from above the steering column that go to a 2 pin plug and unplug. Insert key and measure the resistance across the 2 wires from the steering column, it should measure the same as the key pellet. If more than 4% error, you need a new ign lock which will have new contacts that make connection to the pellet. If more than 4%, connect a fixed resistor the same value as your pellet across the two contacts from the wiring harness and attempt a crank. You can even jump 12v to the clutch safety switch jumper you installed which will force the starter to crank, this will prove the starter is or isn't good.
Old Feb 26, 2011 | 01:22 AM
Blame's Avatar
Blame
I know because when they tested my starter it smoked. I put the new on this afternoon and it run like normal. Plus to get it home I had to push it till it had a good amount of speed. then I hop inside turn the key on put it in 3rd gear and got off the clutch. and it started right up. if the VAT was the problem it would not have started that way.
So I'm 100% sure it was the starter.
Old Feb 26, 2011 | 01:24 AM
THE 383 admiral
this is a lengthy debate???? the highest probable is the Starter solenoid
OP states if he waits a hour + good to go
if it was the key resistor it would not be intermittent... possibly the Ign switch.. not common
make diagnostics quicker... Neutral and jump the solenoid
Old Feb 26, 2011 | 04:12 AM
Blame's Avatar
Blame
There is no more debate. I have a brand new starter and the vette start up again. the problem is fix. But, for some reason people keep trying to solve something that been fix.
Old Feb 26, 2011 | 08:22 AM
rodj's Avatar
rodj
There is no more debate. But, for some reason people keep trying to solve something that been fix.
So next time you might be own your own when you ask for help
Old Feb 26, 2011 | 08:27 AM
78pacer's Avatar
78pacer
When I first put my pace car on the road after a restoration, I grabbed the wifey and drove in 95+ deg temps to Newport RI. I had to stop after crossing the RI border to actually put the T-tops ON due to the brutal sunshine. When I went to restart......CLICK, then nothing. Fortunately I carry a Ballpean with me. A few whacks on the starter and off we went. The first thing I did after getting home was replace the starter and wrapped it with heat wrap. No more heat soak from the headers. All was good.
Mike
Old Feb 26, 2011 | 03:33 PM
Blame's Avatar
Blame
Mike
that is not a bad idea. I need to look into getting some heat wrap.
To No start need help
Old Feb 26, 2011 | 03:35 PM
Blame's Avatar
Blame
IF that what happens then that what happens. It not like I posted on here and got help before. But, this is the first time people kept posting on what it could be after I said the problem was fix.
Old Feb 26, 2011 | 04:07 PM
THE 383 admiral
did you stop and realize when I was responding.... before your posted FIX!!!!!!
I cannot see your response or I would not have posted
Old Feb 26, 2011 | 04:14 PM
87 vette 81 big girl's Avatar
Amen,
Another no start fixed.
Guys get mad when rude to another. As you found out.
