Problems with gas supply after time running
Old Feb 27, 2011 | 01:55 PM
nelsonvazquez's Avatar
nelsonvazquez
Default Problems with gas supply after time running
I have a 1984 crossfire and after an hour or so running motor begins to fail and motor stops, starts and is no gas out of the showers, let it seat for an hour or so and then running again as nothing happens, I changed already gas pump/pump relay/gas filter/temp sensor/EGR valve/cooling fan sensor, 0 code on scanners (4 different garages) I do not know what else to do, can somebody help me find out what is happening?
Old Feb 27, 2011 | 08:59 PM
Sandpiper59's Avatar
Sandpiper59
Can you hear the pump still run when you go to no flow?
1rst step would be determine if loss of flow is because pump stops running or if it is still running but you get no flow to the injectors. Need to know if your chasing an electrical issue or a plumbing issue.
Hopefully some of the guys that know the crossfires chirp in but you may be able to force the pump on through the ALDL and that can help diagnose things too
