Supply/demand or what?
However, ill make an argument that the steel block of an l98 or ltx is a better platform for high levels of boost than any lsx platform. Reverse cooled heads (ltx motors) also work to your advantage.
One other thing the c4's have going for them (at least on my 93 lt1) is a fuel flow RETURN line. This makes it easier for fuel injectors to stay balanced. You will read about guys, on the c5/6 FI site installing a fuel flow return line to support big FI HP. Thats a mod we dont have to do !
lsx intake/head flow advantages are most noted on a N/A applications. While better flowing heads helps for FI, its not what you need to rely on. You can pulley down and make up for it.
If you want to hear about guys making crazy power with boost on sbc or ltx motors, dont look here. Go to the camaro websites. You will read dyno numbers that make you think you are looking at a c5/c6 forced induction part.
solid roller + boost... now you are talking.
Supply and demand was the answer I was expecting but figured it didn't hurt to ask.
Like almost every other newbie 'how to get more horsepower' thread it appears the bottom line, for C4's at least, is $, time, and effort (or go buy something else). That's cool. I'm laying a foundation---got the factory shop manuals, am reading the fuel injection book, have Lingenfelter's book in my amazon wish list, etc. It's been a while since I've done any serious wrenching, though. I'll try making a rational decision when I really understand what's involved (I hope).
The c5 & c6 guy's have it easy, but they paid to get there, so good on 'em. If I really care a year from now I may join 'em. In the meantime I'm lovin' my C4 and dreaming.
Last edited by 3D87C4; Mar 2, 2011 at 03:30 PM. Reason: moving some punctuation & spelling, d;oh!
Id love to hear more about this build. What did you do for fuel pump(s)? Its nice the C4's have fuel return lines, unlike the later C5s and C6s.
just curious, did you know, at time of LSx install, that you would eventually go FI?
I trust you are making more power LSx than LTx, but its my understanding a built LTx (forged bottom end, lowered compression) is not necessarily a bad platform for FI with crazy levels of boost. While still not as good as worked aftermarket LSx heads, ported AFR heads close the gap to the LSx's superior head flows.
I can understand if you are building a road race car N/A. You want lightweight everywhere and LSx aluminum block is going to help you out.
Im trying to understand if I should also be considering LSx route sometime in the future. I may.
LSx advantages (for forced induction):
-more efficient heads
-non-siamesed exhaust ports (ie. you dont have those two center-exhaust ports butting up against each other creating a hot spot)
-better computer for tuning (if you also transplanted the ECM from the LSx donor car)
LTx advantages:
-reverse flow cooling
-extra bolt around each cylinder connecting the block to the head.
-iron block
LTx advantages:
-iron block
used a 2001 fbody computer
used a 2001 fbody computerthats an 8 second setup .....!!!
