'95 wheel alignment
Old Mar 1, 2011 | 01:25 PM
schimek3624's Avatar
schimek3624
Default '95 wheel alignment
I have a '95 convertible with the FX3. I need to get the wheels aligned. Is it a good idea to get 4 wheel alignment? What specs should I use for caster, camber, etc. The car is mostly leisure car. No track use or high performance driving.
Old Mar 1, 2011 | 03:22 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Vette brake products used to have an alignment cheat sheet.
It included specs for street, aggressive street, track, etc.
So check their website or do a search here for "alignment"
Old Mar 1, 2011 | 04:21 PM
sailorsteve's Avatar
sailorsteve
You should absolutely get a 4-wheel alignment. Ask around for a good shop with a competent tech. This will likely not be a chain outlet, but an independent shop. The shop should have the stock specs, also they are in the FSM.
Old Mar 1, 2011 | 04:27 PM
3D87C4's Avatar
3D87C4
c4cruiser sent a link to the alignment specs in a reply to my tire question thread:
Originally Posted by c4cruiser
For alignment, if you go to this page and select "Alignment Specs" you can see some good alignment specs. I use the "Advanced Street" setting for my 87 for autocross and track use but it's still easy to drive on the street.
Also check out this page for some information on the suspension for C4's.
Oh, and I posted pics at the end of my thread but nobody looked, d'oh!
Old Mar 1, 2011 | 05:26 PM
StealthLT4's Avatar
StealthLT4
Check out the VB&P link above. Good stuff! I recommend using the Daily Driver specs. You can also align it yourself, depending on your mechanical inclination. It's really, really easy. I started doing my own about a year ago, after getting sick of shops not giving me what I ask for.
For DIY alignment: http://www.davidfarmerstuff.com/align.pdf
Pretty much all you need is a tape measure and bubble level! A laser-level helps, but I don't think it's necessary.
To '95 wheel alignment
