Rack & pinion inner tie rods
Old Mar 1, 2011 | 03:05 PM
5is1's Avatar
5is1
5th Gear
Default Rack & pinion inner tie rods
Does anyone know how to get the inner tie rods off. I have tried and they will not budge. I do not see any roll pins, or something else holding them on.
Old Mar 1, 2011 | 04:31 PM
sailorsteve's Avatar
sailorsteve
Don't know if all years are the same, what year is your car? The inner tie rods on '92 are threaded into the ends of the rack. You need to remove and disassemble the rack to get the inner tie rods off.
Old Mar 1, 2011 | 04:44 PM
5is1's Avatar
5is1
5th Gear
This is a 94 rack, yes it is out of the car. Are these locked onto the theaded part of the rack , because I cannot get them to budge
Old Mar 1, 2011 | 04:59 PM
sailorsteve
The FSM has detailed assembly and disassembly instructions, with diagrams. The description covers several pages. Can you lay hands on the book?
Old Mar 1, 2011 | 06:35 PM
5is1's Avatar
5is1
5th Gear
What is the FSM ?
Old Mar 1, 2011 | 07:10 PM
espop125's Avatar
espop125
they are staked on and are a pain to get off. I used a very power impact and it still didn't wanna come off. It will though good luck
JackDidley's Avatar
JackDidley
The fat inner end of the rod is smashed flat on one side. Take a cut off wheel and cut the flat part away. Then unscrew the fat part. Right now, I'm guessing you are turning the rod but not really unscrewing anything.
Old Mar 1, 2011 | 08:29 PM
sailorsteve
Originally Posted by 5is1
What is the FSM ?
Factory Service Manual
To Rack & pinion inner tie rods
