Rotor time for the blue monster
Old Mar 2, 2011 | 12:43 PM
69mako's Avatar
69mako
Default Rotor time for the blue monster
Hi all-
Time to replace the rotors (All four) on the Vette (1994 LT-1, base suspension not HD or Z-51) I’m looking for an upgrade in the rotors-what would you recommend and why?
This Vette is drivin on clear weather weekends and might be put to use in some auto crossing this summer. I would like to stay in the stock class.
Old Mar 2, 2011 | 06:54 PM
polo91cnvt's Avatar
polo91cnvt
69mako,
I would just replace with stock. While I don't think it effects your autocross class, the stock rotors will do just fine. Go to your local part dealer and get the gm replacement or the better brand. I started autocrossing last year with 124k on the car and about 5k on the stock gm rotors they worked just fine, even boiled the brake fluild. (I now use synthic dot 3 / 4 from valvoline, but the oriiginal fluild was old at the time.) The stock rotors are easlier to maintain as they don't crack like the drilled, and you don't have to worry about using the parking brake at the track, while I do avoid using it until the brakes cool a little bit. Replace pads with the ceramic pads, they cost more but last longer and may work a little better than stock.
Old Mar 3, 2011 | 08:46 AM
69mako's Avatar
69mako
Thanks for the input, Brembo makes a fine replacement rotor for a fair price
Old Mar 3, 2011 | 08:49 AM
Muffin's Avatar
Muffin
One of our supporting vendors is running a special on up-scale rotors. Might be worth a look.
Found it:
http://forums.corvetteforum.com/c4-p...ices-ever.html
Old Mar 3, 2011 | 09:54 AM
proracr's Avatar
proracr
You should check out BrakeMotive's rotor and pad sale. I don't think that you will beat their prices anywhere, anyhow.
Old Mar 3, 2011 | 12:01 PM
Charleston2012's Avatar
Charleston2012
I just bought some rotors from checkers/oreily. I checked the parts number and it turned out to be raybestos, which is fine. Rotors, as long as they are cut true make no real difference, unless you want it to look good. Brembo, Bendix, Napa, Raybestos etc are fine. Check out RockAuto, as they show you all the different brands and prices in one page.
Pads and fluid make the real difference on stopping. Hawk pads HPS make your Vette stop significantly faster, time after time.
Old Mar 4, 2011 | 08:41 AM
69mako's Avatar
69mako
I'll be sticking with a name brand rotor, I'v seen too many friends try to take the cheap way out with no-name pads and rotors only to hear them cry a few months later because their rotors warped or their pads cracked, disintegrated or squealed like a pig. .
You get what you pay for
Old Mar 4, 2011 | 10:46 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Look at KNS brakes. I just bought some rotors from there. Ken is a good guy to deal with a very knowledgeable. I like DBA rotors because they can take some heat and last.
Old Mar 4, 2011 | 11:11 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Dba rotors and Carbotech pads will work extremley well for you
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To Rotor time for the blue monster
