fuel rail assy removal
Old Mar 3, 2011 | 06:35 PM
Sober1's Avatar
Sober1
Default fuel rail assy removal
What is holding my fuel rail assy on?
Do I have to remove the clips off each injector to remove it?
Does it come off in one piece or do you have to split it?
I have the four hold down bolts removed from the rail assy. Appears as though the injectors are keeping it held to the intake.
Please Advise...........thanks in advance.
Old Mar 3, 2011 | 06:40 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
The L98 fuel rails are connected to the fuel lines at the front, and to the cold start injector line at the rear. Get all three lines disconnected and clear. You may have to remove the AIR valves to get at the fuel lines. The injectors are not fastened to the manifold, The fuel rails hold them down. My rails and injectors came out as one piece. Good Luck.
Old Mar 3, 2011 | 07:32 PM
Sober1's Avatar
Sober1
ITS OUT
Just took more force to pull it out than I was willing to use on the first few attempts
One step closer to pulling this thing out
To fuel rail assy removal
