88 rebuilt project
Old Apr 14, 2002 | 12:12 PM
djbraxton's Avatar
djbraxton
Default 88 rebuilt project
I'm starting my rebuild on my 88 Z52. The only problem I have, is the engine is in parts and I have moved several times. Now that I have retired from the army, I want to start the rebuild again. I'm getting the short block rebuild now, where can I go to find all the bolts, screws and any misc. things I may need. Could the forum also recommend a camshaft that I run without going the Ed.w route....
Thanks alot, haven't posted in a long time
Old Apr 14, 2002 | 12:38 PM
vader86's Avatar
vader86
Default Re: 88 rebuilt project (djbraxton)
do you mean a cam that wouldnt require a reprogram?
Old Apr 14, 2002 | 01:01 PM
djbraxton's Avatar
djbraxton
Default Re: 88 rebuilt project (vader86)
vader86, yes,trying to stay on some sorta budget on this one. My plans are .30 over, hypereutectic pistons. I'm having my heads mill to 52cc. I would like to run a little higher compression, know my concerns are, what camshaft do I use.
Old Apr 14, 2002 | 01:04 PM
vader86's Avatar
vader86
with that much engine work, i dont think iit would be advisable to not reprogram, but i think the LPE 211 cam is small enough to work right for you or maybe some small grind from Crane
Old Apr 14, 2002 | 01:30 PM
djbraxton's Avatar
djbraxton
Vader86, thanks, what kind of programming issues do think I will run into?
Old Apr 14, 2002 | 02:36 PM
vader86's Avatar
vader86
I just dont believe it will be easy to tune it at all without a chip, it just wont run correctly, poor idle, missing at different places in the band and rich/lean problems, etc.
plus you wont have near as much power as you would with a custom chip
[Modified by vader86, 1:36 PM 4/14/2002]
Old Apr 14, 2002 | 09:01 PM
djbraxton's Avatar
djbraxton
Hey vader86,
thanks...
To 88 rebuilt project
