INJECTOR OR VALVE PROBLEM?????
Old Apr 14, 2002 | 04:20 PM
jtjerry's Avatar
jtjerry
Default INJECTOR OR VALVE PROBLEM?????
Since I have my vette (4 years) there is same problem: sometimes car run normal (and it is for about 98% times I drove). But there is THAT GREAT 2% when car runs MUCH better like rocket.
When that happen I can feel that engine running much smoother, feel much stronger and much quiet. Whet it run better I can see that my instant fuel economy is better about 20%.
That 2% great running happen when it want, there is no correlation with weather, with temperature, no matter car run long or just started, simple that better happen suddenly and last sometimes 1 minute, sometimes one hour and gone as come: suddenly.
For 4 years I was trying pinup that problem (I want that 2% all the time!!!)
I changed plugs (3 times, ignition cables, rotors, caps, ECM and another)
Still nothing.
And last I saw that spark plug at 8 cylinder had a lot black oil and another sparks was in perfect condition.
So I replace 8 cyl spark plug with 1 cylinder spark plug. Drove some and checked. And again spark at 8 cyl was oil black wet and another 7 was good. So no spark plug!
Second I done the same with ignition cables and I found that no cables are reason.
In last week I checked that 8 spark plug in that 2% great running condition, and that plug was clean as 7 anthers!
When car next again turn in 98% mode I checked 8th cyl plug and it was black again.
SO PROBLEM IS WITH 8 TH. CYLINDER
You think it is bad injector or something mechanical (valve perhaps?)???
How check?
Any suggestions?
Car is 88 with 80 k miles
Sorry for my English
Hope you understanding what I try say.
Jerry
Old Apr 14, 2002 | 06:44 PM
Togo's Avatar
Togo
Default Re: INJECTOR OR VALVE PROBLEM????? (jtjerry)
jerry, oil can be 2 things....i have the same problem.
in cylinders 4&6 i get oil coating all the time. its either valves or rings. i don't think there is any other way to get oil in there! as far as testing, i have no ideas.....maybe pull the heads off and have a valve job done (although thats not testing) and while they are off, check the cylinder walls for scoring?!
sorry i couldn't be more help, but my solution is i am just gonna replace the whole motor!!!!
good luck
Old Apr 14, 2002 | 07:24 PM
jtjerry's Avatar
jtjerry
Default Re: INJECTOR OR VALVE PROBLEM????? (85_togo)
thanks for answer,
but there is pssibility checking that without pulling heads off????
Jerry
Old Apr 15, 2002 | 09:01 AM
merrick's Avatar
merrick
If you are sure what you see on the #8 plug is oil and not fuel, then you should do a compression check. If the compression check is good, then you are getting oil from around the valve stem (need a new valve stem seal and/or valve guide).
Old Apr 15, 2002 | 09:19 AM
85 Dave's Avatar
85 Dave
Default Re: INJECTOR OR VALVE PROBLEM????? (merrick)
Also do a leak down check on all the cylinders.
Old Apr 15, 2002 | 06:43 PM
jtjerry's Avatar
jtjerry
Default Re: INJECTOR OR VALVE PROBLEM????? (85 Dave)
Today I made compression check. It show no more than 2 - 3% difference between cylinders. Of course when I drove to that test vette run quite good (I know when it run good, I can feel it from the start.)
So test show nothing and that 8 cylinder plug was in good condition (I was sure that, cause today my vette runs quite nice)
I am thinking about change injectors (form 8 cylinder to 1 and from 1 to 8) and when check what will happen .
That crazy. It run bad most of the time and today when I drove for that test she was good running. Ironic...
Jerry
leak down test, what it is?
Old Apr 16, 2002 | 04:30 AM
merrick's Avatar
merrick
Leak down test is putting air pressure through the spark plug hole on the cylinder at TDC. The tool used has dual pressure gages and separated by a calibrated orfice. The leakdown test compares the pressure readings on the gauge. You can also listen for air leakage from the rings or valves.
Old Apr 16, 2002 | 11:10 AM
jtjerry's Avatar
jtjerry
thanks for info
Jerry
Old Apr 16, 2002 | 03:07 PM
wegozoom's Avatar
wegozoom
Does your car have a cold start injector that may be sticking open?
Old Apr 16, 2002 | 03:27 PM
Joe C's Avatar
Joe C
jerry -
this would be a good test to check out injectors!
another test, try swapping out the #8 plug for a hotter plug (one or two ranges), to see if you get that 2% drivability. second, measure the resistance across each injector. they should be (i think) about 5 ohms. if you have an oil problem in #8 cylinder, the hotter plug will help burn off deposits. hope this helps -
[Modified by joe ciechanowski, 1:32 PM 4/16/2002]
Old Apr 16, 2002 | 04:05 PM
jtjerry's Avatar
jtjerry
Default Re: INJECTOR OR VALVE PROBLEM????? (joe ciechanowski)
I checked resistance and driver side all 4 are 14.7 and passenger side all 4 are 16.2. Strange? hhhhmmmmmm....
I have 9 th cold start injector cause it is '88.
Ok, I can disconnect it.
But cold start injector leaking can cause spark plug at 8 th cylinder have that ugly black wet deposit?
Jerry
To INJECTOR OR VALVE PROBLEM?????
