How not to fix an engine problem
(not in a C4 but know a couple of you get it)
1-Hooked vacuum gauge up saw it fluttered, immediately pulled valvecover
2-Found bent pushrods, lots of them.
Fix? Replace pushrods and drive it. If something was bent youd know. Simple.
My Fix
Tear new motor with 60 miles out of car.
Pull heads off discover nothing was broken bent or had contact to elminiate paranoia.
Realize I had cheap pushrods and the motor was fine.
Build 385 stroker, up the compression more cam more porting
Build it to the point it will be as reliable as a cheap crack ho
So in case that mysterious "race of all races" pops up..kind of like the Phantom car in the Speed Racer cartoon shows up out of nowhere Im ready...lol
Its out there I know it.
Oh yes, Then put new pushrods in it.
The car disease only gets worse
My Fix
That is a funny story.
I have done worse things,
Like: after putting on those new headers with the P in A locking bolts , looking up [ as I turn the key] and wondering what that exhaust gasket is doing laying on the windshield wipers?
A Sam Kennison moment follows
Ah.. Ah!! AAHH!! AHHHHHHHHHHHH!!!!!!!!!
I also learned how to put the harmonic balancer back on with the water pump on the engine .
OTOH, my solution to bad injectors was a 383. Seems fair you built one for a p-rod issue!
Are you putting those dart heads back on?
Yes thats all it was. Lobes were a little on the agressive side. IMO maybe that works good with smaller cams/less rpm but perhaps with ones that have a good spring behind them and turn some rpm it may do more harm than good and find weak links quick. Found it lol.
No valve/piston contact. Pushrods were the fusible link, so to speak.
Picked a cam with a genter ramp
-Probably going to reuse the Darts, noone has stepped up and wanted to buy them, would love a set of Comp Port 210s but the Darts will work fine for what Im doing, little big for a 350 though.
Choices were
-Pushrods and run it (cheapest and smartest route)
-AFR C. Port 210 heads, mill heads/shim gasket to up CR and cam it (maybe). Darts were a little big for a 350
-Stroke/cam it, reuse the Darts as noones wanted them. Still available...for a little bit.
Money was just about the same motor was apart anyway so...
Keep the stories coming, misery loves company lol
