thread cleaning chaser
Old Mar 10, 2011 | 09:42 AM
jmrl98's Avatar
jmrl98
Default thread cleaning chaser
Anyone know what size I need for my stock block 85? Jegs & summit have them, but prior dealings with their techs have me hesitant to ask them. Thanks, John
Old Mar 10, 2011 | 09:46 AM
cgantner5150's Avatar
cgantner5150
I just made my own using one of the old head bolts. Grind a channel on two sides of the bolt along it's axis. Works like a charm and cost me $0.00.
Sorry, but not sure of the thread size off the top of my head.
Old Mar 10, 2011 | 09:56 AM
jmrl98's Avatar
jmrl98
Did you use a dremmel to make it? I've done some grinding on some intake parts, but I'd be worried about jackin' up the threads in the block that way. Obviously it worked for you. Interesting.
Old Mar 10, 2011 | 05:05 PM
racebum's Avatar
racebum
you can get a whole kit of multiple sizes at sears for $50, very useful tool to have around over the years
Old Mar 10, 2011 | 06:34 PM
cgantner5150
I used a bench grinder to do it but there is no reason that a dremel wouldn't work. I'll dig up a pic I you need it.
Old Mar 11, 2011 | 07:13 AM
MyFirst90coupe's Avatar
MyFirst90coupe
For the head bolts? It's 7/16-14.
Old Mar 11, 2011 | 09:46 AM
jmrl98's Avatar
jmrl98
Yes, the head bolts. Thanks boys. I may not have been looking in the right place at sears, probably should've asked.
Old Mar 11, 2011 | 09:50 AM
Muffin's Avatar
Muffin
I have a set, must be 20 years old, came from Summitt. Best $10.00 I ever spent.
Old Mar 11, 2011 | 09:55 AM
jmrl98's Avatar
jmrl98
I looked at summit && jegs, and they are a little more expensive now. Go figure. So muffin, I won't need to lift my engine to get the new cam in? I've pulled the stocker out to the member, and it does seem that if you maneuver it right, the journals and such will miss the member. Just not ready yet time-wise.
Old Mar 11, 2011 | 10:29 AM
Muffin's Avatar
Muffin
Ten bucks don't buy what it used to.
To thread cleaning chaser
