Rough running at light with A/C on...
Old Apr 14, 2002 | 08:40 PM
GlockLT4's Avatar
GlockLT4
Default Rough running at light with A/C on...
Now that it's starting to become A/C weather, I had it on and I pulled up to a light and it would run a little rough in an oscillating maner. (Like.... chugachugachuga .. chug. chug chugachugachugachgua chug chu chua chugachugachuga)
What would cause this? The only thing I can think of is because of my vacuum being really high at low rpms & idle. I am yet to figure out how to get my vacuum up with this cam and the 383... any ideas?
Old Apr 14, 2002 | 09:38 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Rough running at light with A/C on... (Glock'94)
when you say running rough, do you mean about to stall?
What do you mean by this? replace low with high, and high with low? I asume you mean vacuum is down?
Old Apr 14, 2002 | 09:57 PM
GlockLT4's Avatar
GlockLT4
Default Re: Rough running at light with A/C on... (bill mcdonald)
Yes, it tries to stall.
I'm not really sure on the vacuum. All I know is everyone that has seen my datamaster logs says the vacuum is high, which tends to be the norm for a beefier cam.
Old Apr 14, 2002 | 10:19 PM
bill mcdonald
Hmm, have you tried putting an actual vaccum gauge on it?
I think a stock L-98 pulls baout 18-19 vacuum at idle, when I put my zz9 in it pulled 13-14 PSI at vacuum.
Do you have to set the IAC on the LT1 like the L-98?
I set my min idle (IAC reset) with the AC on, it leaves the idle at ~800 with AC off, which is fine on my 6 speed, It also smoothes out the idle on the ZZ9 up there, I dont know what that will do with your Auto trans though....
Old Apr 14, 2002 | 11:14 PM
GlockLT4's Avatar
GlockLT4
According to the computer, I'm pulling like 40psi at idle. Idle is adjusted through the computer. I have it set to 800rpm in gear as well.
[Modified by Glock'94, 9:15 PM 4/14/2002]
To Rough running at light with A/C on...
