lowering kit help
Old Mar 11, 2011 | 02:47 PM
87stocker's Avatar
87stocker
Default lowering kit help
i used that 5 min epoxy that is shown in the suspension rebuild sticky. the other day i went out and one of the peices is off of my spring so i thought i would test the strength of all of them and with a light tap from a hammer all of my poly chunks fell off the spring. any hints?
Old Mar 11, 2011 | 03:30 PM
StealthLT4's Avatar
StealthLT4
Did you sand it pretty vigorously, then clean well and let dry? The epoxy doesn't work very well on a smooth surface; you need to rough both side up so it has something to adhere to, then be sure to clean all the little fiberglass/plastic bits off afterwards.
Old Mar 11, 2011 | 03:36 PM
racebum's Avatar
racebum
do the above and use acetone to clean the spring before you install it.
Old Mar 11, 2011 | 04:06 PM
87stocker's Avatar
87stocker
thanks guys i will do both of those. this place never fails me
Old Mar 11, 2011 | 04:07 PM
383vett's Avatar
383vett
I heard these springs don't like acetone or harsh solvents. They can delaminate.
Old Mar 11, 2011 | 04:41 PM
racebum's Avatar
racebum
there's a coating over the glass strands. maybe if you bathe the spring in it you could break down the glues. a quick wipe with the rag just removes grime. acetone leaves no residue and is easy to get. if you had paint quality wax n grease remover that would also work and is more tame
Old Mar 11, 2011 | 08:10 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
A lot would also depend of the quality of the epoxy you use. The cheap 5-minute stuff is more geared for home/craft use. I don't believe it would hold up very long outside. You'd at the very least want to get a product is is rated for outdoor use.
Old Mar 12, 2011 | 12:22 AM
StealthLT4's Avatar
StealthLT4
May be true as well. When I lowered my front, I bought some nice 2-part marine-grade epoxy. It worked wonders! And still does, whenever I need to join 2 pieces of plastic together.
To lowering kit help
