how hot until she blows
Like above 230- 240 degrees F.
Your C4 will happiest if Stock with water temps of 190 - 220 degrees F during normal driving and WOT runs.
Brian
With the proper coolant mix and pressure cap, the coolant won't reach the boiling point until close to 260° F.
At 220, your cooling fans probably are not even on yet.
You won't "blow" a head gasket until you get up over 260.
Because once the water temp gets over 228 degrees F C
in a C4, the temp can run away - climb higher quickly.
I have an Electric Cooling Fan Manual Bypass switch hooked under the dash of my 87 Vert.
Flip the switch on, and my coolant temps never get over 195 degrees F regardless of long idling periods, or working under hood of my car with the engine running.
Get a large home furnace style blower.
Put it about 2 to 3 feet in front of your C4.
That will help greatly keeping the coolant temps down.
Blow the air forcefully to the Front Lower Air dam.
Air will be Rammed into the radiator then.
Dont want to overheat the engine while breaking in your New camshaft and Lifters.
brian
There is only 1 brand dino oil that will protect the engine at those very high water temps.
Maybe 3 synthetic oils that will protect the same also.
I speak from 1st hand experience. Racing Pontiac Powered cars for years.
Blowing headgaskets is nothing new to me.
People hate talking about oils here on C4, so I wont.
But I do know what actually works and better than most everyone else does here.
Just a few other professional racers and engine builders here on C4 know what actually works best like I do.
Brian
And if there wasn't sufficient airflow inside a shop, using a large fan would have helped to keep temps down assuming that air could move thru the radiator.
Did you install a new thermostat? Was the cooling system filled properly and did you use a 50-50 mix of anti-freeze and water? Any air pocket could easily cause a rise in temps and can impair coolant flow.
What temps did you see? Did the main cooling fan come on? Should have come on around Does your car have the auxiliary fan in front of the A/C condenser? If so, did it come on?
Iron headed cars can generally handle just a little more but I'd pull off at 260 as well.
I would pull those plugs right now, don't run it.
So discoloration in the spark plugs indicates piston wear or just a head gasket leak? There is definitely moisture in the oil....it showed over filled only after the break in and there seems to be coolant coming out of the exhaust. We pulled a valve cover also and there is indication of moisture in the cover as well.
Do you think I am looking at another head gasket job? Do you think it was my temp that caused this or some other problem? This sucks.
You live and learn is such ways.
Advice from others and me don't mean much unless you apply them to your own Corvette.
Attention to details make every bit of difference in the final outcome of engine repairs and builds.
Also applies to Transmissions, Rear differentials, suspension work, electrical repairs, even ignition & EFI tuning.
Something went drastically wrong during your last headgasket replacement.
Brian
He makes you work for free.
Forget about equal rights, freedom of speech, OSHA, Illinois State Laws, ect, because they dont apply in Illinois.
Especially Chicago.
Its called GM Flat Rate.
And it sucks *** like the Service Writer does to you when you bring your vehicle in for repairs. lol
You learn to make repairs right and correct the 1st time around perfectly every single time and make or beat that GM Flat Rate Book.
Or you dont eat for the week and your family at home starves.
Brian
