Cam
Old Mar 13, 2011 | 07:43 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Originally Posted by JackDidley
What do you think of this cam ? http://www.jegs.com/i/Comp-Cams/249/...oductId=760004 May be putting a non roller block in my car. 180 cc heads, Miniram 10.8:1 compression.
Comp Cams #249-12-366-4
"XFI" 268 Hydraulic Flat Tappet Camshaft
Chevy 262-400ci 1955-98
Lift: .520"/.515" w/1.6 Rockers
Duration: 268°/280°
RPM Range: 2000-6000
Doug, Too bad you're not looking for something a bit more mild. I bought a full Comp Kit K12-268-4 before I decided to go retro-roller that I'd be willing to let go for a reasonable price.
Old Mar 13, 2011 | 08:29 PM
JackDidley's Avatar
JackDidley
I'll keep you in mind. Probably be a week before I make a decision.
Old Mar 14, 2011 | 04:39 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
I also have a Crane 114132 cam and lifter kit. Also bought before I decided to go retro-roller. New in box. Let me know if you're interested.
Old Mar 14, 2011 | 08:30 AM
JackDidley's Avatar
JackDidley
The Crane is too small for sure. I will let you know when I decide. I may end up staying with my ZZ4. I currently have a project in the house to finish so it will be a few days before I get to the car.
Old Mar 14, 2011 | 10:26 AM
tequilaboy's Avatar
tequilaboy
From the opposite end of the spectrum, how about something like a 280 mega cam with 64 degrees of overlap (single pattern 232/232 on a 108 LSA):
http://www.summitracing.com/parts/ISK-201281/
Old Mar 14, 2011 | 03:21 PM
JackDidley's Avatar
JackDidley
The 108 LSA is a bit tight. My heads and intake (1204 intake gasket) are sort of selected to work up to 6000 RPM. Overlap may a problem, tuningwise. Stock converter and 308 gears may be weak off the line. Truth is, I like weak off the line, keeps tirespin down and its easy on the Dana 36. I'd really like a Hot cam. Good compromise for street/performance. Still kicking ideas around.
Old Mar 14, 2011 | 09:53 PM
tequilaboy's Avatar
tequilaboy
Here's another interesting cam. Just stumbled upon it:
http://iskycams.com/timingchart.php?...mber=CL-201274
Old Mar 14, 2011 | 10:40 PM
JackDidley's Avatar
JackDidley
I totally forgot about Isky. I will go to their site tomorrow when I get a chance to do some reading.
Old Mar 14, 2011 | 11:08 PM
cv67's Avatar
cv67
St. Jude Donor '05
Love the way Iskys run,switching from Comp back to Isky myself.
108 I think can be tuned provided its not too big. Hit up Mseven to see what he thinks. The 108 lsa comes on very hard youll feel it when the powerband is there.
Old Mar 15, 2011 | 01:21 AM
mtwoolford's Avatar
mtwoolford
don't have any personal experience, but most lifter companies seem to be offering non roller hydraulic lifters with some sort of provision for forced oiling onto the cam lobe face; some extra bucks, but nothing compared to an after market "retro" roller set up.
