Simple Performance Mods
Old Mar 14, 2011 | 11:15 AM
vabatwho714's Avatar
vabatwho714
Default Simple Performance Mods
With the exception of Intake and Exhaust. I'm looking for recommendations for some simple performance mods I can do to my 91 L98. It has stock injector, so I know that's one area I can improve. What other options short of pulling the motor out.
Old Mar 14, 2011 | 11:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
Bigger injectors wont give you any more power.
Intake and exhausts are usually the first and best things to change.
All the air foils, fancy coils, wires, K&N air filters, couplers IAT sensors all that nonsense is just that. Nonsense. Maybe all of them combined may make a teeny bit of difference but doubtful
If anything some say removing the frisbee on the water pump and cutting the airbox lid help some. Get it in perfect tune if it isnt then save for some real mods.
Old Mar 14, 2011 | 11:45 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Make sure everyhing is 100%. Cap, rotor, plugs, wires and fuel filter. If you have over 100K, replacing the injectors with stock sized or slightly bigger, 24 lbs, can help. Once that is all good I'd try underdrive pulleys or 1.6 roller rockers next.
Old Mar 14, 2011 | 12:07 PM
oldalaskaman's Avatar
oldalaskaman
the best things I've done to my 87 127,000 , was to install Bosch design III injectors from FIC, a vender here, CompCams 1.6 roller tip rockers w/new springs sold by Ecklers, another vender here, and while I had it apart, all new valve seals, putting intake and exhuast seals on all valves. That got it back to good running, a good power band, and good mpg. and got rid of that 'startup' smoke. I had good compression to start with. If you dont have the good compression , you need to fix that first or everything else is wasted. The venders prices were better than than manufactors and I didnt have to do a bunch of research to make sure things would do what I wanted. once you have a good base, the other mods ,air intake/exhuast, will work better. IMHO
Old Mar 14, 2011 | 07:53 PM
John A. Marker's Avatar
John A. Marker
with cuisinartvette and Paul Ruggeri.
Do some reading.....check out VADER86's web site.
Old Mar 14, 2011 | 09:43 PM
steven mack's Avatar
steven mack
I agree a good tune up and 1.6 roller rockers would be a good start.
Old Mar 14, 2011 | 10:40 PM
racebum's Avatar
racebum
years ago i managed to make a 1990 6spd car run a 13.1 without getting into the heads and cam.
headers, cat back. ported stock tpi, k&n air filter or tpis foam, cut filter lid, TB coolant bypass, waterpump frisbee and cheapo 1.5 aluminum roller rockers, 1.6's should be worth even more on the stock cam
To Simple Performance Mods
