Broke axle?
Here is the knuckle, hopefully I can smooth out the places the cog on the axle bit in to.
I broke this on a horrible burnout, 15psi, and launching at around 3000-3500. I didn't side step-it on the launch. I don't know what's up but it's :bs .
Not it could be that the clutch was ready to go anyway, being the 3rd owner, I had no idea how much abuse the car had gone through, but chances are the previous owners were just as hard on it as I am.
With the six speed car being the daily driver, I decided to make the tires the weakest link, they are easier(and sometimes cheaper) to replace especially if you are far from home.
So I bought another car for the track and have the best of both worlds.
i think mine started with the ujoint tho...then 1/2 shaft, then the spindle (axel) and then the bearing, but can't really tell the sequence, so feel fortunate that you only broke THAT. My spindle broke just like yours...same spot and angle. Mine went during a launch and i usually go low 1.6x shorts, but i'll bet yours might have cracked during the burnout, cause 2 sec shorts shouldn't have broken that. I replaced mine with a hardened unit from Tom's Diff. Good luck on the repairs.
BTW, which side is that from. Mine was drivers side
[Modified by ralph, 9:47 AM 4/15/2002]
Bummer about the axle. But in all liklehood, the failure was a long time in coming. Typically, a failure in a solid axle owes to defect that was there from day one.
It could have a been a casting inclusion of some contaminate going back to the ingot from which the part was rolled and or stamped, the machining technique used to make the part, or a thousand other things along the way. Replace it and assume it'll never break again. Go in peace my son. Cire96
These are definately a weak link in the system. I was running 1.9 60' time the first run, then broke it on the second run when I upped the clutch dump RPM to 4400. I thought I broke the rear end as the car simply quits moving and the noise it pretty bad from inside the car.
FWIW, these break a LOT! The guy I bought my motor from had a handful of these things from when he ran at the track. Pretty much everyone I know that has a pretty quick setup has broken these axles once or more.
[Modified by Vette92, 2:38 PM 4/15/2002]
Cheers.
[Modified by 89 Paul in cal, 7:11 PM 4/15/2002]
Chris, how much were the hardened units? I would have went with those, but I needed my car now, but I'm still curious about the costs.
Even though I've drag raced every car I've owned I'm probably done with this one aside from a few trips down on street tires. I'm a poor college kid, and I can't break stuff like this all the time considering it's my only means of transportation. I have a cam, and my friend is doing my heads, but I'm not sure if I'm going to go that route. My car has 49K miles and I need it to last 100-125K. The cam is a CC305 on a 112 LSA, what would your guys opinion be as far as motor longevity with that cam?
After pulling the knuckle, halfshaft, etc, I saw how easily the rear comes out now, so I'm considering pulling it and sending it off for gears. Am I correct in thinking that after the halfshaft, knuckle and bottom swingarm is off that the only other bolts holding the rear in is the large top bolt on the batwing and the bolts connecting the driveshaft?
When I disconnected the knuckle I unbolted the bottom swingarm at the knuckle not the center section. I never touched the camber bolt and I had scribed it so I know it hasn't moved, but my alignment seems to be off. Maybe it's all in my head, but I'm not sure.
To answer another question, I broke the driver's side axle.
I ordered from Tom's also $150.00 each plus shipping. Talking to Tom had me believe that the past 4 times I bought yokes from the dealer, I got ripped off. I've talked to some of the racers in my area that run Vette's (IHRA/NHRA) & they swear buy the parts he sells them.
[Modified by ENJ, 12:18 AM 4/16/2002]
As for the wheel sensor, I left mine alone. It did take it out too, but I already have a bad one in the front so until I replace the front bearing (wheel sensor is a part of the front ones) I will leave then both bad and just remove my lights. I can drive without ABS/ASR just fine. ;) Those sensors are not cheap by any means for new ones.
Chris
*FWIW- We're currently tooling up to build some Chromoly half-shafts and driveshafts for C4's. These shafts will be cryogenically treated. We'll also be cryo treating the drive axles (diff side) and the drive spindles, the bearing caps, ring and pinions, etc. in the rearends. We're also experimenting with studding the caps and adding a preload stud to the rear cover to prevent deflection. My main goal is to improve the D36 with the stronger D44 coming as an afterthought. I've currently got the 36 out of my wife's 85 and am R&Ding it right now. The 44 will follow very shortly afterwards (in fact the 44 will come out of my car and we'll abuse the 36 on my stick car with slicks to see how it will hold up). We're currently looking at 60-90 days before we have products ready to go... Sorry for the advertisement but I though some on here might wanna know!!
-Jeb Burnett
