Fuel Filter replacement method
Old Mar 14, 2011 | 04:38 PM
Azriel's Avatar
Azriel
Default Fuel Filter replacement method
It seems pretty straight forward. Unbolt it, R&R. My question relates to how to relieve the pressure in the line. I read online that you should unplug the fuel pump fuse and let the car run til it stops? That sounds like it would do more harm than good. Any input?
Edit: It's an 88.
Old Mar 14, 2011 | 04:44 PM
Mrs. glass car's Avatar
Mrs. glass car
I know from experience that that won't work on my 96'. With the fuel pump not operating the engine won't run.
There is a Schroeder type valve by the fuel rails that you can use to relieve the pressure.
Old Mar 14, 2011 | 04:58 PM
Azriel's Avatar
Azriel
Originally Posted by glass car
I now from experience that that won't work on my 96'. With the fuel pump not operating the engine won't run.
Oop, forgot to put that bit of info. Edited for clarity
That valve would make quite a mess, right?
Old Mar 14, 2011 | 05:01 PM
tehcarguy's Avatar
tehcarguy
Keep your mouth closed when changing it.
Old Mar 14, 2011 | 05:32 PM
Azriel's Avatar
Azriel
I have heard that.
Old Mar 14, 2011 | 06:27 PM
383vett's Avatar
383vett
Let the car sit for a while before changing the filter. The pressure will bleed off. On the other end, I disconnect the larger of the two lines coming out of the tank. Some people pinch the rubber hose. I've changed filters before with fuel running down my arms onto my trouble light (old incandescent). I'm surprised I'm still around.
Old Mar 14, 2011 | 06:52 PM
rodj's Avatar
rodj
As noted, disconnect the supply line to prevent fuel continuing to siphon out while the filter is off which it will do because tank is higher than filter
Have rags to mop up the fuel contained in the lines which will run out
Old Mar 14, 2011 | 08:15 PM
383vett's Avatar
383vett
And definitely put out the cigarette.
Old Mar 14, 2011 | 08:32 PM
78pacer's Avatar
78pacer
Man, what a sloppy mess this R&R can be. There are a few threads on this. Do a search. I pulled the fuse and ran it dry, crimped the feed and return lines from the tank and pulled the bitch out from the top. That's prolly the easiest method. The trick is to keep the fuel from coating you.
Mike
Old Mar 14, 2011 | 08:44 PM
Sky Vette's Avatar
Sky Vette
Changed one in an '89. Did it in the morning before driving. Placed a pan under the work area. No bleeding a fuel line or pinching. Loosened the outgoing line bolt first and put a finger of a disposable glove over that line. Then disconnected the incoming line bolt and quickly removed the old filter and put the new one inplace connecting the incoming line first. Then reconnected the other line and fully tightened both end bolts... done. Lost maybe 4 ounces of gas. Why make this a more complicated procedure than it needs to be?
Old Mar 14, 2011 | 09:23 PM
tblt44's Avatar
tblt44
do it when the tank is almost empty and remove the gas cap.Just a little gas will come out.
Old Mar 14, 2011 | 09:29 PM
sailorsteve's Avatar
sailorsteve
I took an old filter and used the fittings to make caps for the lines when the filter is off. Actually, you mostly need it on the supply line to the tank, finger tight is good enough for the short time you need it.
I cut the fittings off the old filter, cleaned them thoroughly, cleaned them again thoroughly, blew them out with air, and plugged the cut ends with some polyurethane mastic adhesive I had lying around. You could use any kind of goop that resists gasoline.
Also, the standard strategy of waiting until the tank is ≤ ¼ full helps greatly to avoid a dangerous mess.
Old Mar 15, 2011 | 02:41 PM
Azriel's Avatar
Azriel
Got it done! Thanks for all the tips and help.
I ended up just taking off the gas cap and that seemed to help. I pretty much had a full tank, too. Lost maybe a cup full. Took me about 40 minutes because I couldn't find metric wrenches in my FIL's garage.
To Fuel Filter replacement method
