Help! Cooling fan doesn't run
Old Apr 15, 2002 | 10:36 AM
OnDVirg's Avatar
OnDVirg
Default Help! Cooling fan doesn't run
The main cooling fan on my 85 stopped working...sort of. It still comes on around 220 degrees when the auxilary fan kicks in. I performed the tests that the manual shows:
- grounded the wire from the fan switch and the auxiliary fan came on but the main one didn't.
- jumped terminals at the relay and the main fan DID come on. So it's not the fan motor, or no power situation.
So I thought, bad relay. Put in new one....same thing.
I also replaced the switch (mainly because the insulation broke when I was taking off the connector) so I'm pretty sure that's OK as well.
Anybody have some thoughts what I can check? I'd hate to pay the dealer man, but I'm almost at that point. Thanks for any help. :cheers:
Old Apr 15, 2002 | 11:09 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Help! Cooling fan doesn't run (OnDVirg)
Sounds like your fans are operating normally.
Old Apr 15, 2002 | 11:16 AM
vettedan's Avatar
vettedan
OnDVirg-Is'nt the main fan supposed to come on at 220 degree? The aux. fan comes on when the A/C is on. I think this is how my '91 worked? I always mod the fans so they both come on at the same time using a thermal switch. It turns the fans on at 180 degrees. Check out Eckler's or mid America for this kit. You can also add a switch that will force the fans on when you are in traffic or inbetween auto x runs.
Dan
Old Apr 15, 2002 | 11:50 AM
OnDVirg's Avatar
OnDVirg
Default Re: Help! Cooling fan doesn't run (PeteL)
Oops. Mistyped above. The main fan IS NOT coming on @ 220 degrees, but the auxilary is. That's why I thought I was so clever replacing the relay. But still no fan.
Old Apr 15, 2002 | 02:59 PM
weekendwrench's Avatar
weekendwrench
Maybe the temp switch is not working. I think it is in the front of the intake below the throttle body.
When you jump the A and B terms on the ALDL does the fan come on?
To Help! Cooling fan doesn't run
