Transmission losing power
Old Mar 16, 2011 | 04:04 PM
Biglurr54's Avatar
Biglurr54
Cruising
Default Transmission losing power
I am having trouble with my transmission in my 92 vette. It has 130,000 on it. When I'm driving everything shifts fine. If I punch it off the line the tires will hook up and rocket the car or burn out. If I punch the gas while I am already doing like 25 mph then the engine revs like it normally did but the power isn't getting to the tires. Is this a failing trans or a bad torque converter or maybe an electrical issue? It started last year on a hot august day when I was racing around with a guy in a lambo. The car had been running hot... Around 225. Any ideas?
Old Mar 16, 2011 | 08:32 PM
sailorsteve's Avatar
sailorsteve
Does the engine overrev as if the trans is slipping?
Old Mar 16, 2011 | 09:18 PM
Biglurr54's Avatar
Biglurr54
Cruising
No the car revs like it did when it would worked normally. It doesn't over rev or anything.
Old Mar 17, 2011 | 02:26 PM
freedog81's Avatar
freedog81
I would say torque converter, when mine went bad it would do okay cool but once heated it would slip like crazy.
To Transmission losing power
