Timing Chain & Water Pump
Old Apr 15, 2002 | 12:01 PM
Barrier's Avatar
Barrier
Default Timing Chain & Water Pump
Well at 100k miles I guess I have to start doing more than thinking about changing the chain and water pump. Any body have any suggestions about the way to go? I think the original has the nylon cam gear, I have always used a Cloyes double roller replacement with the hardened gears is that what most of you have done? Anybody replaced with stock chain and gears? And if so why? Are there any problems with double roller on an '86 Aluminum head Corvette all stock ( non roller rockers). Any noise, wear ,interference problems etc?
Anybody have any advice about the type of water pump, GM or replacement and if so what brand? Is there a special model used on the '86, aluminun, cast iron, short long or they all the same?
At the moment I have had no problems with cooling or timing shift, just mileage creeping up.
Barrier :)
Old Apr 15, 2002 | 02:26 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Timing Chain & Water Pump (Barrier)
Get a Double Roller timing chain from Summit, and contact Stewart Components, and get one of their High Flow Water Pumps for around $100-$150. Then, you're set to go :D
Old Apr 15, 2002 | 02:40 PM
scorp508's Avatar
scorp508
Removed my timing set yesterday. Have fun getting it out. :)
Old Apr 15, 2002 | 06:02 PM
Barrier's Avatar
Barrier
Default Re: (scorp508)
BTT
Old Apr 16, 2002 | 11:56 AM
Barrier's Avatar
Barrier
Default Re: (Barrier)
BTT
Any other thoughts?
Barrier
Old Apr 16, 2002 | 04:02 PM
Rick86's Avatar
Rick86
I'm running a Cloyes double roller, for about 20,000 miles, just replaced timing chain cover and upon inspection of the chain everything was fine.
Old Apr 17, 2002 | 06:58 PM
Barrier's Avatar
Barrier
Default Re: Timing Chain & Water Pump (Rick86)
Thanks for all replies.
Now I just have to do it.
Barrier :) :)
To Timing Chain & Water Pump
