What plugs and wires?
Old Apr 15, 2002 | 03:49 PM
TODDZWER's Avatar
TODDZWER
Default What plugs and wires?
I have an 89,with the basic mods. What plugs should I use and what wires(ps I want red wires) check out site http://www.toddsz51.vettepics.com
Old Apr 15, 2002 | 04:06 PM
James94LT1's Avatar
James94LT1
Default Re: What plugs and wires? (TODDZWER)
I use the MSD 8.5 wires the are red. I have had them for 3 years now and they are in great shape. They are suppose to be very low resistant wires. They also have very good boots.
I run a bosch platinum plug, some will argue with this but I have had nothing but good results with them as well. Not the +4 things, the standard plugs.
Old Apr 15, 2002 | 05:16 PM
Rob90's Avatar
Rob90
Default Re: What plugs and wires? (James94LT1)
I like my Taylor wires.
Old Apr 15, 2002 | 05:42 PM
WINNER's Avatar
WINNER
Cruise-In II Veteran
Default Re: What plugs and wires? (Rob90)
Rapidfire plugs too :cheers:
Old Apr 15, 2002 | 05:43 PM
vader86's Avatar
vader86
Default Re: What plugs and wires? (WINNER)
Rapidfires and MSD wires, anything with MSD on it is good for ignition
Old Apr 15, 2002 | 05:52 PM
65Z01's Avatar
65Z01
A nice setup would be HyperTech coil/cap/rotor, MSSD 8.5mm SuperConcuctor wires (you'll need looms too) and A/C Delco plugs with cut-back ground electrodes gapped to .045"-.048".
For some good center-bolt wire looms, check out the Summit catalog.
Old Apr 15, 2002 | 06:17 PM
black bart's Avatar
black bart
My vote is for MSD super conductor wires and they are red. I have been through three set of wires in less than a year before installing the super conductors. I put on a new set of blue max wires and my ignition was hot enough that it made fubar out of them in about 100 miles. For those that don't know fubar is F++ked up beyond any recognition.
Old Apr 15, 2002 | 11:57 PM
ezmoney92's Avatar
ezmoney92
Default Re: What plugs and wires? (black bart)
Allways used 8.5 Magnecor Race wires and never had a problem. My brother uses them on his GN and T-Type and you know them things get hot and he's never had a problem with them. :seeya
Old Apr 15, 2002 | 11:58 PM
ezmoney92's Avatar
ezmoney92
Default Re: What plugs and wires? (ezmoney92)
Oh, the Magnecors are red also. :seeya
Old Apr 16, 2002 | 12:05 AM
scorp508's Avatar
scorp508
I run AC Delco Rapidfire #5 and MSD Superconductor 8.5mm wires. The wires will not fit your stock wire looms, they are too big.
Old Apr 16, 2002 | 12:56 AM
ezmoney92's Avatar
ezmoney92
Default Re: (scorp508)
Yep, another plus for Magnecor. Their 8.5's do fit the stock looms, check out their site they explain all that good stuff. :seeya
To What plugs and wires?
