Ecklers Adjusable fuel pressure regulator
Old Mar 19, 2011 | 03:36 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Default Ecklers Adjusable fuel pressure regulator
It came with a new hat and then this circular metal "coin". It was SUPPOSSED to come with instructions but none included and no response back yet from them. What is with the coin?
Old Mar 19, 2011 | 03:56 PM
STL94LT1's Avatar
STL94LT1
Is this for an LT1?
Old Mar 19, 2011 | 04:05 PM
M.J.L.'s Avatar
M.J.L.
No, Sorry L98 85-91 year.
http://www.ecklers.com/corvette-high...1985-1991.html
"Coin" below fpr hat in link.
Old Mar 19, 2011 | 04:08 PM
STL94LT1's Avatar
STL94LT1
The adjustment screw pushes against the coin.
Old Mar 20, 2011 | 05:08 AM
blackozvet's Avatar
blackozvet
I put one of those on my '85, the coin is just a washer for the screw to press onto as you screw it down, it sits on top of the diaphram assembly, i ended up leaving mine off because the bolt was too long and hit the plenum, it works fine without it.
the reason i used a longer one was because i wanted to use a lock nut on the bolt, just for info the afpr held pressure longer with the lock nut in place.
To Ecklers Adjusable fuel pressure regulator
