I currently have a 3.25 diameter pulley on my blower. The small pulley is pushing way to much psi for my stock motor, what size pulley is about 4-5 psi?
Thanks,Brandon
Other options to limit the boost wouild include: limiting the revs, limiting the throttle opening at WOT, adding a boost limiting valve, or resticting the airflow to the blower.
Of these options, restricting the airflow into the blower with a passive flow restrictor is the most practical. You just need to figure out the right orifice diameter, and find a way to install between the blower and air cleaner. Something on the order of 2.25"-2.5" diameter would work.
Thanks,Brandon
You can download the spreadsheet at the link below and use it to determine the correct size pulley for the amount of boost you want to run.
