Fuel Filter Change on 91
Old Apr 15, 2002 | 05:48 PM
fourthrail's Avatar
fourthrail
Default Fuel Filter Change on 91
How hard is to change the fuel filter on a 91 without getting covered in gas? Anyone have any pictures or advice?
Thanx...
Old Apr 15, 2002 | 08:23 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Fuel Filter Change on 91 (fourthrail)
Its not too bad. Its tuffer in a convertible cause of the x-brace. Just remember park on flat and to remove the gas cap. Remove the shield and its easier to get if the car is high. Get the flow direction right. My gas bath was minimal last time (for a change). :smash:
Old Apr 15, 2002 | 08:29 PM
White91's Avatar
White91
Default Re: Fuel Filter Change on 91 (blk90rdstr)
You may also want to discharge the fuel pressure first. Start the car and then pull the fuel pump fuse and when the car stalls the pressure is gone. This should keep the bath to a minimum, or at least make it only go down. Other than that it's not too bad of a job. It's on the frame rail by the passanger foot well.
Old Apr 15, 2002 | 08:35 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Fuel Filter Change on 91 (White91)
Just have all parts handy and be ready to work quick. Makes life easier...
Old Apr 15, 2002 | 11:41 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Fuel Filter Change on 91 (LPDesRoche)
I didnt get much at all either- and all i did was take off the gas cap. The car ran SOOOOO much better afterwards, I could not even blow through the old one.
To Fuel Filter Change on 91
