84 vette wheel/off-set
trans am gta bbs style wheels for the correct off-set ??????
thanx,guys
:confused:
What this means is you can fit a 38mm offset into the rear wheelwells. This is why the '84-'87 cars can use the ZR1 11" rear wheels (they were designed for a 36mm offset) without extending beyond the wheelwell. Starting in '88, they changed the offsets to 56mm front & rear on everything except the ZR1 (those of you with the GS have a 50mm offset on the rears).
As far as if the TA wheels would work, the bolt pattern SHOULD be the same, but I would check before spending the $$. If it were mine, I'd buy some ZR1 wheels and slap them on. Put 275's or 285's up front and 315's in back and have some fun.
