Plug gapping??????
Old Apr 16, 2002 | 01:41 AM
BAdAzZV8's Avatar
BAdAzZV8
Default Plug gapping??????
My plugs are gapped to about .045, what should they be at, and how do I get them gapped right?
Old Apr 16, 2002 | 02:22 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Plug gapping?????? (BAdAzZV8)
I run my cut-back AC Delcos at .048".
Old Apr 16, 2002 | 08:46 AM
MinnesotaRagtop's Avatar
MinnesotaRagtop
Default Re: Plug gapping?????? (65Z01)
any mods that might have changed your gap requirements? or is that for a out of the box type 350? In rereading your signature, I am guessing its not stock...
[Modified by MinnesotaRagtop, 6:47 AM 4/16/2002]
Old Apr 16, 2002 | 08:53 AM
65Z01's Avatar
65Z01
Default Re: Plug gapping?????? (MinnesotaRagtop)
The HyperTech coil puts out 53kV compared to 38kV from the stock unit. Combined with the lower resistance TPIS wires, this allows me to run with a .045"-.048" gap.
With a stock ignition I suggest the stock gap, i believe .035". I would still run with cut-back ground electrodes for a more efficient burn though.
Old Apr 16, 2002 | 01:21 PM
emoshn's Avatar
emoshn
What is the stock plug gap for a 92 LT1? I thought it was .050.
Old Apr 16, 2002 | 02:04 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Plug gapping?????? (emoshn)
LT-1 stock plug gap is .050
Old Apr 16, 2002 | 03:04 PM
James94LT1's Avatar
James94LT1
Default Re: Plug gapping?????? (Springer's 95)
Stock is .050 on the LT1. I run .035 on my bosch plugs and my car seems to really like it there!
scorp508's Avatar
scorp508
The plugs on my L98 are at 0.035 right now.
Old Apr 16, 2002 | 04:40 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: (scorp508)
I gap mine at .035 for the Nitrous. LT1 stock gapping is .050 as stated above.
Old Apr 16, 2002 | 07:26 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: (Vette92)
But if I cut the electrodes it would be even a bigger gap, like going from a .045 to .060
What exactly do you guys do exactly to the plugs?
Old Apr 16, 2002 | 07:31 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: (BAdAzZV8)
All you do is bend the tip. Get a plug gap tool, usually just a round disk with an inclined edge. Check the gap with the tool, use the tool to open the gap by prying up on it.
I hope that is what you are asking.
Old Apr 16, 2002 | 07:37 PM
BAdAzZV8's Avatar
BAdAzZV8
Yeah, that is what I was asking. I wasn't sure if I could bend the tip or not, and I have the gap tool.
Thanks,
Anthony
Old Apr 16, 2002 | 07:38 PM
BAdAzZV8's Avatar
BAdAzZV8
OK, so now I'm looking at getting a good gap. Some are saying .035, but you say that you did that for your nitrous setup, would it be good to do that if not running nitrous?
Old Apr 16, 2002 | 07:53 PM
James94LT1's Avatar
James94LT1
Again this maybe something you fine tune for your car but .035 is where mine runs best, judging by mph.
Old Apr 17, 2002 | 11:45 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I would set it to stock plug gap of .050" for a N/A setup.
To Plug gapping??????
