Do I need to re-program ECM???
Old Apr 16, 2002 | 12:52 PM
gsvette's Avatar
gsvette
Hoon
Default Do I need to re-program ECM???
I finally got the 96 GS back together. It starts, idles, and runs pretty good as far as I can tell. It is definately stronger than stock.
The engine mods are; Accel 300+, MSD wires, open-lid, K&N, Holley 52mm TB, ported intake, ported LT4 heads, GMPP hot cam, Hooker shorties, flowmaster cat back.
The question is: do I need to have the PCM re-programmed?
If it will get me even more power then I have no problem doing it, but, it is running very good now. Of course I could be wrong, since I have not driven the car in over a year. The only issue that I have noted is the exhaust has a slight rotten egg smell. I have heard this can be caused by running lean.
There are currently no DTC's being set or any other PCM problems. Any advice would be appreciated.
Old Apr 16, 2002 | 01:34 PM
vader86's Avatar
vader86
Default Re: Do I need to re-program ECM??? (gsvette)
to get full power, yes
Old Apr 16, 2002 | 03:23 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Do I need to re-program ECM??? (vader86)
Assuming it is dyno tuned.. otherwise it is a Crap shoot
To Do I need to re-program ECM???
