If you haven't installed them, you might want to think about exchanging them for the nongreasable ujoints. They are stronger without the threaded hole for the zerk fitting.
Well I've already done one side and the reason I'm asking for the thead details is, it was a bitch getting a grease gun on the joints, so am thinking of using an angled grease point and just want to be sure of the thread type.
Get an adaptor for your grease gun that has a pointed tip. The tip pushes the check ball that seals the fitting back into the fitting & will let grease into the joint.
