Issues please look.
Old Mar 28, 2011 | 05:19 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Default Issues please look.
Ok so I was driving to work everything was good to go. I get off the interstate and stop at a light. When I went to take off the engine sounded like a wrx boxer engine. I can smell fuel and the car is ironing like crap and has reduced power. No check engine lights oil pressure is good cooling temp is normal. No signs of a fuel leak
It's consuming gas at an alarming rate a quarter tank in 40 miles.
Blown 383 stroker upgraded everything.
Old Mar 28, 2011 | 05:31 PM
STL94LT1's Avatar
STL94LT1
Try the C5 Tech section.
Old Mar 28, 2011 | 05:59 PM
MVP'S ZO6's Avatar
MVP'S ZO6
My bad I thought I posted this in the c5 section.
Old Mar 28, 2011 | 06:37 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default I'm not much help - sorry
But I would check everything underhood - did something come loose - maybe that you didn't notice at first? Have you made any changes recently - what was the last thing you fixed/ messed with
Haven't heard of sudden unusual fuel consumption with loss of power - without any other lights/warnings signs etc
Not sure if you have one / added or not - the return fuel line - could it have come loose - ?
I'm sure some more experienced folks will help you figure it out!!
Old Mar 29, 2011 | 12:03 AM
oldalaskaman's Avatar
oldalaskaman
I really like this one, respectfully, bob
Old Mar 29, 2011 | 10:30 AM
Chuck Tribolet's Avatar
Chuck Tribolet
A quarter tank in 40 miles? That's not running rich (it
would not run), it's a leak which is FIRE HAZARD.
And what do you mean by "ironing" and "wrx boxer"??
Speak English.
Chuck
Old Mar 29, 2011 | 10:54 AM
cv67's Avatar
cv67
St. Jude Donor '05
Blown FPR?
Check your oil see if it stinks like gas
Dont drive it.
Old Mar 29, 2011 | 12:37 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Speak English.
Chuck
He means the Subaru WRX engine. The engine is call a boxer.
is a 4 banger looks like the VW bug set up.
Old Mar 29, 2011 | 12:51 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Speak English.
Chuck
Thanks for the helpful information Chuck. I appreciate it. I fat fingered the keys on my iPhone. you know what they say, "Once ya learn good English can't nobody change ya".
The facts are as follows. I drove 40.1 miles and consumed 1/4 tank of unleaded premium fuel.
The car still runs but sounds rough like a boxer engine found in the Subaru WRX. The engine I speak of is a horizontally opposed piston internal combustion engine. There are no external fuel leaks. I had the car towed home last night. I will run further test on Wednesday and Thursday to determine and correct the cause of the malfunction.
Old Mar 29, 2011 | 01:13 PM
bac22's Avatar
bac22
The car still runs but sounds rough. On other words like a boxer engine found in the Subaru WRX. The engine I speak of is a horizontally opposed piston internal combustion engine. There are no external fuel leaks. I had the car towed home last night. I will run further test on Wednesday and Thursday to determine and correct the cause of the malfunction.
Almost sounds like you cat has become clogged which I believe can happen if your fuel is running rich for a long time.
Old Mar 29, 2011 | 07:18 PM
MVP'S ZO6's Avatar
MVP'S ZO6
No cats.
Old Mar 29, 2011 | 09:06 PM
VetteMed's Avatar
VetteMed
My vote is for the FPR. Seems most likely based on symptoms.
Old Mar 29, 2011 | 11:13 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Pressure is still being regulated after the FPR according to my gauge
Old Mar 29, 2011 | 11:46 PM
jfb's Avatar
jfb
When you ask for help, always include the year, no one here is clairvoyant.
Old Mar 30, 2011 | 12:18 AM
MVP'S ZO6's Avatar
MVP'S ZO6
I guess so.
For what it's worth the car is a 2002 ZO6
I actually didn't mean to start this thread here.
To Issues please look.
