I've got a 96 and every now and then while parked the hatch will actually pop open. I actually hear the locking mechanism activate, has anyone else had this happen before?
I will say my PKE did start acting a little strange towards the end of last year, so maybe the problem is related.
Turning the System Off
1. Take the ignition key out of the ignition.
2. Press DOOR on the transmitter until the door locks cycle (about two seconds).
To turn the system back on, just repeat the steps.
To check that the system is off, turn on the ignition. The PASSIVE KEYLESS ENTRY light on the Driver Information Center should not come on. If the light does come on for a second or two, then the PKE system is still on.
You can also check whether the system is on or off by closing the door and moving away from the vehicle with the keys and transmitter. If the doors lock, the system is on.
If you are working around your vehicle and keeping your keys with you, you might want to turn the PKE system off. If you don’t, the transmitter will keep locking and unlocking your doors.
If that doesn't determine it, I'd start looking for shorts. The hatch switch on the back edge of door is probably susceptible to corrosion from the crappy window outer seals. Good luck.
No, it's not the programming of the PKE, not sure what it is. And it's pretty random, but the problem is I can't go anywhere and park the car since the last thing I want to have happen is the damn hatch pops open by itself. May just pull the fuse for now.
My '96 has the same problem. I'm confident that the PKE module is hosed, and is randomly closing the circuit to ground for the hatch release relay. Opening up the dashboard will be required to deal with this, so for now, I've temporarily disconnected the connector from electric solenoid back at the latch, and have strung a pull-wire from the latch around under the trim panel with it exiting behind the passenger's seat. A gentle tug on the wire pops the latch manually. This works well, and it's been too damned cold here this winter to mess with it.
Another possibility is that the hatch switch inside the console is wired into the selector at the shifter. That is supposed the keep the hatch from opening once in gear.
Live well,
SJW
Yeah...I'm thinking the same, my PKE isn't acting right. And I just had the damn dash all apart to evict a damn mouse, so I'm going to become an expert at dash removal!
He didn't chew on any of the wiring...well at least from what I can see...but now I'm wondering if he did.
Not sure, haven't had a chance to look at it more closely. I seem to recall that there was a fuse for the rear hatch, but if not I'll just disconnect the solenoid connector or maybe wire switch inline that I can toggle.
The hatch release relay controls the application of +12VDC to the hatch release solenoid. The other side of the solenoid is always grounded.
The hatch release relay has +12VDC applied to its coil winding at all times (presuming the fuse is installed and not blown). The relay is triggered by having a connection to ground completed on the other side of its coil winding.
There are three paths to ground for the relay's windings:
1. Through the pushbutton hatch release switch in the center console, in series with:
a) The neutral safety switch (automatic trans car)
or
b) The parking brake switch (manual trans car)
2. Through the hatch release switch on the driver's door panel's trailing edge, in series with the door ajar switch.
3. Through a solid-state switch inside of the PKE module.
Path 1 requires two switches to be closed to complete the series circuit to ground. When the car is parked, presumably one of those switches will be closed, but the one in the center console will not, and it's exceedingly unlikely that it will close sporadically without being jostled, vibrated, etc.
Path 2 requires that two switches be closed in order to compete the circuit to ground, and neither of these switches should be closed when the car is parked and the doors are closed. Safe to say this isn't where the problem lies.
Path 3 requires only one switch to be closed; the solid state switch inside of the PKE module, which is controlled electronically. I think this is the only reasonable explanation for this misbehavior.
The wiring diagram in the FSM (Section 8A-134-0) seems to indicate that pulling the hatch release fuse will only disable the hatch release mechanism, so it's probably a safe way to make sure the hatch stays down when you need it to stay down. Disconnecting the wire from the solenoid will guarantee that it doesn't open while the car's parked.
