Water pump removal
Old Mar 28, 2011 | 07:30 PM
FireRescue's Avatar
FireRescue
Default Water pump removal
Ok, I am in the process of putting my 92 back together with extensive mods. I am going with an electric water pump. I have upgraded cam, and timing chain. Going with the 96 timing cover. My question is when I removed the gear for the water pump it leaves a opening to the block. Do I need to close this off or do I leave it open. If I need to close it what do you use? I have welded the timing cover hole.
Old Mar 29, 2011 | 10:46 AM
STL94LT1's Avatar
STL94LT1
No, just leave it open.
