Help my A/C Compressur does not kick in!
Old Apr 16, 2002 | 02:48 PM
MrJay's Avatar
MrJay
Default Help my A/C Compressur does not kick in!
I went to get some R12 put in to my system but I could not get the A/C compressur to kick in, it is not the fuse and when I pull out the code on the A/C controler I get code 09 Low Freon.
Can any body help me it is getting hot here..... :(
Jay
Old Apr 16, 2002 | 02:58 PM
cesar's Avatar
cesar
Default Re: Help my A/C Compressur does not kick in! (MrJay)
if you have the electronic controls take the batt terminal out for 20 minutes to reset the computer is the only way it can not be jumped like others
Old Apr 16, 2002 | 03:02 PM
scorp508's Avatar
scorp508
I don't know about yours, but my compressor will not kick in if I am too low on R12.
Old Apr 16, 2002 | 03:07 PM
MrJay's Avatar
MrJay
But how do you put the R12 in if you cant get the compressur running because I was told that it had to be running to get it in.
Jay
Old Apr 16, 2002 | 03:57 PM
Black87c4's Avatar
Black87c4
I tried to turn my air on yesterday and the compressor clutch wouldn't start either. Checked the fuse but didn't actually put a meter to the connector yet. I did have a small leak last year, low freon could be the answer. That stuff is not cheap these days.
Old Apr 16, 2002 | 03:59 PM
soundkillr's Avatar
soundkillr
disconnect the battery for 20 minutes. As soon as you hook it back up, and start the car, the a/c should auto start. Hook up the connections, and start the recharge.
Old Apr 16, 2002 | 04:01 PM
MrJay's Avatar
MrJay
No you are right Black87c4 but Im so lucky that I get it free I have a friend that does service a/c on airplanes and he is willing to fill it up for me but I just nead to get the compressur running first so he can put it.
Jay
Old Apr 16, 2002 | 04:04 PM
Black87c4's Avatar
Black87c4
Send me some :yesnod: :lol:
Old Apr 16, 2002 | 04:09 PM
MrJay's Avatar
MrJay
I will do that Black87c4
But I just got of the phone with the Dealer and they told me that you have to pump it in there until the compressur kicks in and if they do that then it will cost about $120 that is a lot when you can get it for a free... :nonod: I hope I can find a way to do it myself but if I know them they have made it so that you have to take it there..... :sad:
Jay
Old Apr 16, 2002 | 04:18 PM
Black87c4's Avatar
Black87c4
As long as you have a schrader valve wouldn't think that it would be a problem, if I remember right. I took mine to firestone last year, it was low but not by much but If it's very low this time it will cost $$. If its that bad I'll have to find out where the leak is or just swap over to the new style.
Old Apr 16, 2002 | 06:54 PM
weekendwrench's Avatar
weekendwrench
There is a low pressure switch on one of the refrigerant lines that keeps the compressor from running when it is low on refrigerant. You need to uplug the wire to the switch and jump the wires at the connector with a paper clip to allow the compressor to run while you add the refrigerant. One the systyem has a charge you can plug the connector back together.
Old Apr 16, 2002 | 07:07 PM
vader86's Avatar
vader86
Default Re: Help my A/C Compressur does not kick in! (weekendwrench)
unfortunately i cant get my new compressor until the semester is over, until then i have to pray for sub-80 weather and take the top off
it was ungodly humid too today
Old Apr 16, 2002 | 09:56 PM
MrJay's Avatar
MrJay
weekendwrench do you know where this switch is we did try to jump so lines there but I guess we had the wrong one.
Jay
Old Apr 16, 2002 | 10:00 PM
MrJay's Avatar
MrJay
vader86 I feel for you I was driving my car in that weather too and with the top off and the windows down it was still to hot, I hope I can get it fixed soon so I can drive my baby, I hope you get it fixed soon too.
Jay
Old Apr 16, 2002 | 11:05 PM
Rich_01659's Avatar
Rich_01659
one of the hoses going to the compressor will be slightly larger than the other. the larger line is the suction line and the low pressure switch will be in that line some where. on the 94 it is near the passenger wheel well, with luck the 91 will be the same.
Old Apr 17, 2002 | 12:47 PM
MrJay's Avatar
MrJay
TTT
Old Apr 17, 2002 | 07:31 PM
dlmeyers's Avatar
dlmeyers
This issue has come up twice in the last 5 days. The C68 electronic controller will use software to cut out the compressor when the cycle count is too high. To clear the controller, unplug the battery, wait a few seconds (30 seconds should work just fine), and then reconnect. Now wait for 2 minutes and don't touch any buttons. The computer is moving the mixing door through the full range of motion and will store the settings. Start the engine and turn the air on. The compressor should start. If you let it run too long without getting in the R12, the software will again kick in and shut down the compressor. I am assuming you have a set of gauges. Not sure how low the system gets before you have to bypass the low pressure switch. Hope this helps. If you have a service manual, let me know and I will give you the page numbers for more infomation.
dlmeyers 90 coupe zf6 3 speed shocks
To Help my A/C Compressur does not kick in!
