Outer window-seal question....
Old Apr 16, 2002 | 05:47 PM
lampedusa's Avatar
lampedusa
Default Outer window-seal question....
Have any of you guys replaced your outer window seals? I have an '89 and ordered new ones, and I was wondering if there is anything I need to know before ripping the door apart. Maybe I don't even need to rip the door apart? Well, please help, because this is really annoying...
Old Apr 16, 2002 | 06:49 PM
SonnyinVA's Avatar
SonnyinVA
Default Re: Outer window-seal question.... (lampedusa)
i did mine... it's really easy but you do have to take the door panel off. only takes at most 30mins-1 hour per side depending on how fast/slow you are. don't forget the screws behind the door handle etc... you shouldn't have to pull hard on anything except the lil cover that snaps onto the sliding door lock mechanism. make sure you have a drill to drill out the old rivets (don't be too aggressive, you don't want to accidentally drill thru the door), and a rivet gun and some relatively small rivets to rivet the new seal on (because the mounting location is pretty shallow a bigger one won't fit very well). that's it!! anybody else got anything to add?
is there an easy way to get the seal to look as straight as the factory ones? mine look a lil wavy...
Old Apr 16, 2002 | 07:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I bought my '88 I paid about $100/side to have the dealer do em; later I found out it was a realy easy job. Ouch.
Old Apr 17, 2002 | 02:36 AM
84FromHell's Avatar
84FromHell
don't be afraid
once you get the door panel off it's a piece of cake.
don't be afraid if you have to unplug all the wires inside the door panel, the plugs are all different so you can't put it back together wrong. you may not even have to unplug them at all, i did because i replaced the inner seals too.
you may want to go to a nut and bolt supply house and get some of those nylon thingies that pop into the door that the door panel screws into. sometimes they are called bath tub nuts, but there are other names for them. You can buy them at Pep Boys for $1.69 each, or .16 each at a fastener store. mine were old and brittle and some broke.
hope you ordered GM seals :chevy
Old Apr 17, 2002 | 08:00 AM
lampedusa's Avatar
lampedusa
Default Re: Outer window-seal question.... (84FromHell)
Thanks you all for your input, $100 bucks a side? Ouch yeah thanks for saying something, I might have lost that money myself, also. Thanks again guys.
Old Apr 17, 2002 | 08:03 AM
lampedusa's Avatar
lampedusa
Oh I did order GM seals. :yesnod:
Old Apr 17, 2002 | 11:17 AM
Black84's Avatar
Black84
don't be afraid
When I did mine, I placed a cardboard box on the garage floor just underneath the door panel. I allowed the door panel to "rest" on the box without having to unplug any of the wires. While it is true that all are different it does take time to re-connect everything if you don't do something like "the box under the door panel" trick.
Old Apr 17, 2002 | 12:06 PM
GS 163's Avatar
GS 163
Default Re: Outer window-seal question.... (Black84)
I need to do mine someday. :rolleyes:
Old Apr 17, 2002 | 12:30 PM
a851yy07's Avatar
a851yy07
Default Re: Outer window-seal question.... (SonnyinVA)
I did mine about 8 months ago and they looked a little wavy so i took the door panel off and double checked that all of the clips were in the holes and 2 were not. just took it off and made sure that they were all in the holes redid the rivets and looks perfect now.
Don
Old Apr 18, 2002 | 12:10 AM
Rick Williams's Avatar
Rick Williams
Try your chevy dealer for parts. I paid $31.00 each for both sides on mine.
Old Apr 18, 2002 | 01:29 AM
92LT1Roadster's Avatar
92LT1Roadster
Default Re: Outer window-seal question.... (Rick Williams)
It is simple but it can be frustrating. I guess my 92 was a little different. When you line up the clamps insure that you place the clamp tip in the center of the hole. I know this may sound stupid to some of the guys that have done this but my holes were elongated not exactly round. I started sliding the first clamp in at the end of the hole and the other holes were not lining up. I had to pull the dam@$ thing up and it made a bruise on the seal. So just be warned. My passenger side was perfect but I may do the driver side over sine the seal has a little warp in it. my seals were $25 from Jeff Coop
Old Apr 18, 2002 | 03:52 PM
Hotwhlz85's Avatar
Hotwhlz85
https://www.corvetteforum.com/techti...D=63&TopicID=2
I haven't done this yet but it's in the Tech tips for a C4. This says you don't even have to take the door panel off.
Hope this helps.
Ron (Hotwhlz85)
:cool:
Old Apr 18, 2002 | 11:49 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Outer window-seal question.... (Hotwhlz85)
Hope this helps.
Ron (Hotwhlz85)
:cool:
It's not that tough to pull and replace the panels. I'd be afraid to try it the other way.
Just did mine two weeks ago.
http://forums.corvetteforum.com/zerothread?id=274115
To Outer window-seal question....
