Cleaned Radiator and !!WOW!!
Old Apr 16, 2002 | 06:01 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Cleaned Radiator and !!WOW!!
My advise to anyone that hasn't cleaned the front of their radiator is to DO IT NOW before the hot weather rolls around! The whole job took about an hour; not hard at all. When I first took the top radiator shroud off and looked inside I was stunned:eek: ! Nearny half the radiator was completely covered in leaves, cigarette buts, and what not. Before this job, my engine would reach 213 deg. fairly quick before my fan would engage. Now it won't go above 185 deg.! BTW I'm running 100% distilled water + water wetter... :cheers:
[Modified by NUckINg FuTS, 4:31 PM 4/16/2002]
Old Apr 16, 2002 | 06:22 PM
Vic'89's Avatar
Vic'89
Default Re: Cleaned Radiator and !!WOW!! (NUckINg FuTS)
This is on my list of things to do asap.
Did you have to pull the fans out also ?
Does the shrould come off easily ?
Vic
Old Apr 16, 2002 | 06:32 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
It really is hard to believe how much crap gets in there and how big a difference it makes to clean it all out. Did you pull the radiator and get the gunk out between the fins too? My fins were packed so bad it looked like the radiator had been dipped in mud. Everyone that has a C4 needs to do this.
Old Apr 16, 2002 | 06:36 PM
NUckINg FuTS
Default Re: Cleaned Radiator and !!WOW!! (Vic'89)
I only had to remove the two upper fan bolts to remove the shroud. As for the shroud itself, I didn't completely remove it because the trans line wouldn't come loose. I kind of laid it off to the side still leaving plenty of room to work.
Old Apr 16, 2002 | 07:08 PM
vader86's Avatar
vader86
Ill have to do that when i get my compressor and 160 stat installed when the semester is over
Old Apr 16, 2002 | 08:13 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
You can get SOME of the stuff out from the top. But if you want the full treatment, pull the radiator out and clean it.
You might be suprized what is caught up INSIDE those fins too!
Old Apr 16, 2002 | 08:14 PM
scorp508's Avatar
scorp508
You've got a couple of things that block the shroud from coming out all the way. The upper hose on the left and the coolant sensor on the right. removing the top hose should be fine if the system is cool. Unplugging the sensor will drain the radiator to that point, so I slotted the shroud beneath it. :)
Old Apr 16, 2002 | 08:31 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re:
I have my top shroud trimmed at the side ends so it can come off anytime without disconnecting anything.DId the mod when I had to replace the rad itself.
Btw,youre not running any coolant(antifreeze) at all?Just water and a water wetter?If so,electrolysis may be a problem down the road.Be sure to check into that.Its very corrosive to aluminum heads and intake manifolds.
Old Apr 16, 2002 | 08:42 PM
NUckINg FuTS
Default Re: Re: (Bill's86Coupe)
Ahh, water wetter has a built in additive to prevent electrolysis :yesnod: :cheers:
Old Apr 16, 2002 | 09:00 PM
Aggravated4life
Default Re: Re: (NUckINg FuTS)
It does?? Cool! Didnt know that...may be a mod/additive Ill try sometimes.
Thanks for the headsup.
Old Apr 16, 2002 | 09:02 PM
GlockLT4's Avatar
GlockLT4
I reallllly need to do that. I just don't have any time. You have to drain coolant don't you? Or can you leave the hoses attached and do this?
I just haven't had any time to do anything with my car (besides drive it places) lately.
Old Apr 16, 2002 | 09:54 PM
joecaver's Avatar
joecaver
Default Re: Re: (Glock'94)
Hey Glock'94 to do it right you need to pull the radiator all the way out and clean the fins as well. There is a good paper posted in the C4 tech tips section on how to do the whole thing. I followed it when I did mine and it was very accurate. You will be very happy with the results. I had always heard that C4's were supposed to run hot, "that's how GM made them" is what I had heard. Not true. Clean the shroud and the fins and it will not be the same car. Mine runs much cooler, around 170 to 180 I'd say and it used to be right next to the red line all the time.
Old Apr 16, 2002 | 10:08 PM
PeteL's Avatar
PeteL
Water by itself has a much higher ability to remove heat from the engine than the normal AF/ coolant mixture. Water wetter has some additives that will help with short term corrosion and wetting agents (like regular coolant). Not sure what else is in there. Maybe some RedLine experts can help us out here. Hib posted months ago that WW additive package is similar to DexCool with organic acid corrision agents (as I recall, but I'm old).
Also remember that distilled water has a very low pH, somewhere around 5.5; and this is fairly acidic. Dionized water has a pH of around 7.0 which is not as reactive, however it will tend to degrade fairly quickly to a more acidic condition without pH buffers. No way WW can supply the RA to prevent an acidic coolant condition for a long time.
WW is a solution for increased cooling in a necessary situation. I would not use WW and water on the street. Standard coolant mixtures are much better suited for normal street and track use.
Pete
Old Apr 17, 2002 | 05:11 PM
2012 coupe's Avatar
2012 coupe
Here is what I put on mine to stop the problem.
I put it in because I had the new Griffen installed to take care of the heat problem in the summers.
Now it runs around 180 degrees on the freeway and 185 degrees around town in traffic at about 78 degrees outside temp.
:D :flag
Old Apr 17, 2002 | 06:13 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
I need to do mine soon also, it's running real hot. :eek:
I can't even imagine what's behind there. I could of swore last time I looked at the radiator I saw a furry tail of some sort and a pair of eyes staring back at me.
To Cleaned Radiator and !!WOW!!
