Replacing a 4L60E Transmission
Old Mar 31, 2011 | 10:16 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Default Replacing a 4L60E Transmission
I'm helping a C4 friend of mine replace the 4L60E transmission on his recently purchased '94 coupe.
Is there anything on a C4 to be especially aware of during the procedure?
Old Mar 31, 2011 | 10:28 AM
383vett's Avatar
383vett
A factory service manual will give you step by step instructions. There might be a sticky above.
Old Apr 1, 2011 | 10:01 AM
Quicksilver Vert 01
The rebuilt transmission will be delivered today, and we're installing it this weekend using a garage with a lift.
We don't have access to the factory service manuals, so any tips on doing the replacement would be appreciated!
Old Apr 1, 2011 | 12:51 PM
Keystring's Avatar
Keystring
Since the 4l60e shifting is electronically controlled, the only thing you have to do is take the old one out and put the new one back in. Just make sure everything is hooked up correctly.
You might want to consider getting a new torque converter as long as you have the tranny out.
Old Apr 1, 2011 | 12:56 PM
toptechx6's Avatar
toptechx6
This is the sequence I recall, hope it helps
Disconnect the negative battery cable (don’t skip this step)
Drop pan and drain transmission, reinstall, pan with a couple of bolts
Remove starter and flex plate cover
Remove torque converter bolts, push converter back
Disconnect shift cable and unplug wiring
Mark driveshaft and differential yoke for index
Disconnect drive shaft at diff, pry forward.
Secure U joint caps with electrical tape, then pull left and back
(may require bending heat shields to remove)
Support transmission with trans jack
Remove two C beam bolts at trans extension housing
Remove or loosen C beam bolts at differential
Pry trans to left to clear C beam and lower slightly (will take effort)
Disconnect trans cooler lines using flare wrench while holding trans fittings
Use a long extension and flex socket to remove bellhousing bolt holding fill tube, remove tube from trans by pulling up
Support rear of engine with separate stand
Remove remaining bellhousing bolts
Pry trans back to clear dowels and lower
Old Apr 1, 2011 | 01:07 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Using the FSM will allow you to find the answer that could take you half a day to find here.
Buy the FSM is worth every penny.
Old Apr 1, 2011 | 02:25 PM
Quicksilver Vert 01
Transmission is a Jasper rebuilt, and we are installing a new torque converter.
Great write-up. Exactly what I was hoping to find. Thanks!
I have a set of FSM's for my '01 C5.......absolutely worth every penny.
The '94 that we're working on is a friend's recent purchase.
Old Apr 1, 2011 | 04:50 PM
JackDidley's Avatar
JackDidley
The hard part is getting the exhaust out of the way. 94 has huge cats and the supports are held by the bellhousing bolts. I think there is a trick to it but cant remember, its been a year.
Old Apr 2, 2011 | 04:32 AM
toptechx6's Avatar
toptechx6
Yeah, duh! :o That should have been second on the list above, must have gone AWOL during cut and paste, thanks for your help.
Old Apr 2, 2011 | 09:16 AM
Quicksilver Vert 01
Yeah, I just assumed that the exhaust would have to be lowered for clearance. Thanks for mentioning it though.
Old Apr 2, 2011 | 09:19 AM
twin540's Avatar
twin540
Get youself about 3ft of extentions for removing bellhousing bolts.
Old Apr 2, 2011 | 09:40 AM
toptechx6's Avatar
toptechx6
Seems like it has to come down for almost everything except an oil change on a C4.
Old Apr 2, 2011 | 09:49 AM
Quicksilver Vert 01
We should be able to put all of ours together to get the right length. There's a Harbor Freight store about 10 minutes away too.
It's time to get this job started. Thanks again guys!
To Replacing a 4L60E Transmission
