Should I change fuel pump before nitrous install?
Old Apr 17, 2002 | 10:10 AM
AS84's Avatar
AS84
Default Should I change fuel pump before nitrous install?
I'm getting a fogger system gathered up for my 90 super ram setup. Should I change my stock fuel pump or leave it alone? I plan on running a 150 shot and I figured it might be preventative maintence.
Old Apr 17, 2002 | 02:49 PM
XTwinTurbo's Avatar
XTwinTurbo
Default Re: Should I change fuel pump before nitrous install? (AS84)
Yes,
Fuel pump is a cheap replacement and easy to change at home (about 45 minutes to change mine).
The stock pump is good for about 325-350 HP and you will need to go to another higher flowing pump to handle the possible 400-450 hp you plan on making. I suggest you install a Walbro 255lph high flow pump. Should be under $125 if you shop around.
Old Apr 17, 2002 | 04:05 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Should I change fuel pump before nitrous install? (XTwinTurbo)
At the minimum, put a Walbro in it. GSS-307 or GSS340 is a direct replacement for the stock units.
Old Apr 17, 2002 | 04:17 PM
NavyVette89's Avatar
NavyVette89
I replaced mine also and I found out that the Holley and Granatelli brand are both identical Walbro fuel pumps. But the Holley was about 50 bucks higher. Granatelli lists thier pump for a mustang but it is the same pump as the Holley for the Chevy.
Jeff
Old Apr 17, 2002 | 04:59 PM
AS84's Avatar
AS84
Default Re: Should I change fuel pump before nitrous install? (NavyVette89)
thanks for the help, I'll definately be replacing the stocker!
Old Apr 28, 2002 | 02:14 AM
Bruce's Avatar
Bruce
Walbro pump a must. Last yrs I installed a NX kit on my 93LT1 w/ top end package. Running stock pump and Walbro 255lph inline. On the dyno its lean out at 4200rpm. Then we replaced the intank stocker with Holley 255lph. For top end mods car with 100hp shot, you will need dual 255lph fuel pumps.
Bruce
93LT1 Conv w/ZF6
Blown D1 383ci/N2O is in the works
[Modified by Bruce, 12:15 AM 4/28/2002]
Old May 24, 2002 | 11:41 PM
mshay's Avatar
mshay
Default Re: Should I change fuel pump before nitrous install? (Vette92)
Where can the best proce be found on the Walbro pumps?
To Should I change fuel pump before nitrous install?
