85 tach filter access
Old Apr 6, 2011 | 04:30 PM
Tcasberg1's Avatar
Tcasberg1
Default 85 tach filter access
What is the procedure to acces the tach filter for replacement on my 85
Old Apr 6, 2011 | 04:56 PM
floridamale's Avatar
floridamale
If it’s in the factory location driver’s side upper engine bolt to transmission housing, disconnect from distributor light beige wire. You will have to remove the distributor cover on plenum and move around wire loom to fine the bolt. Good Luck
Old Apr 6, 2011 | 07:29 PM
Tcasberg1's Avatar
Tcasberg1
Thanks, got it
To 85 tach filter access
