Massive oil leak!! Help!!
I've had oil leaking onto my converter and burning for some time now. Not really enough to do warrant a major issue but enough to be really annoying. After a quick inspection one evening from driving I noticed what appeared to be oil leaking from around the oil filter. I thought that over time the filter had loosened up some or the gasket my have gone bad so i planned for an oil change the next day since it needed it anyway.
So I changed the oil and filter and cleaned everything up. i noticed oil splattered around where the oil cooler mounting and just figured it was where interstate speeds had maybe blown the leaking oil around and didn't think anything else of it. I drove the car to work that afternoon and had no smoke when i pulled in and figured I was right and it was a simple fix. Drove home the next morning and by the time i got home I thought the car was on fire there was so much smoke. Looked under the car and there was oil 'leaking' from where it had been before around the filter. I looked a bit harder and noticed that it looked like the oil was steadily dripping down the oil cooler but I couldn't actually see where it was leaking from. I looked from the top and didn't see that much oil leaking from anywhere. I went through about a quart of oil in 20 miles.
The only thing I know of on the back of the engine that would leak that much oil is the pressure switch but I really didn't see any coming from that. I didnt see how an oil change would make it start leaking all of a sudden like that. I use Mobil 1 10-30 and have ever since replacing the engine. The engine has about 80k miles on it now. I've also noticed as of recently that I am starting to go through a lot of antifreeze but I don't have a noticeable leak anywhere at all which leads me to think the head gasket but I don't notice any smoke at start up or anything.
I'm completely puzzled on this but have to do something quick since that's my only vehicle right now and I'm thinking it's not a good idea to drive it with it leaking that much oil. Thanks for any info you guys may have.
Good luck!
Jeff
I also found some antifreeze leaking down towards the front of the engine which may be where I am losing coolant from. Could that possibly be from the front of the intake manifold as well or is it more likely the water pump or mounting gaskets?
PS
the sender thats over the filter is the oil temp sensor. its not in the pressure port, just free falling return oil for a temp taste.
Clean the area with dish soap & water or simple green...nothing harsh! that harness back there is fragile and has too many important circuits to risk a chemical degreaser bath.
with leesvet. The sending unit and pressure unit screw together and are found on the back side of the block behind the distributor. They will leak massive amounts of oil in a short period of time. This is what they look like....
Glad you caught it.
I know first hand how fast oil squirts out...
A few months ago when I was diagnosing a no-pressure condition I simply started the motor to see what kind of flow I really had... like a garden hose..
Imagine 50 lbs behind a good leak...oil everywhere.
On the other hand I have also been looking for my antifreeze leak and found it leaking from the front of the intake manifold. So regardless of whether the oil leak is from the manifold or not, it's all gonna get changed.
I've gotten everything off except the fuel rail and manifold. At one time I had dexcool in the system thinking it was better and I was wrong. Is there a good way to clean the orange build up out while I have everything apart? I've run cleaners through the radiator before but it's never really gotten it all out.
I have been running orange dex in my L98 for 5-10 yrs and never had an issue, but I also flush thru a permantly installed fitting & valve so there is zero remaining old coolant in the system.
Draining is inadequate, contamination remains unless its pushed out and when the thermostat blocks a major point of discharge or circulation there must be a "power-flush" with a water hose attached.
You might try the bottle brush, but other than that I do not know what else would be safe to get inside to remove and goop or residue. Perhaps returning to dexcool? I remember hearing some stories about gel and clogging and such but every one of them came from having some green left or someone adding dex to a system that was still full of green in the block where it had not been flushed out thourghly.
try to leave the rail w/inj on the manifold unless you are going to replace O-rings for the injectors.
As for as the orange stuff, it's not really buildup so much as it is more like a rust colored coating on anything the antifreeze goes through. I've done several complete flushes over the years more as preventative maintenance than anything. But anytime I flush the system and put clean antifreeze in it always discolors to a rusty dexcool color and I am positive I have gotten all the dexcool out long ago.
I did notice buildup in the two rear coolant ports on the head and intake though. It was kinda like mud. Best I can figure out is that stopleak I had put in during the winter gathered there since the gasket between the heads and manifold was completely blocking both rear coolant passages. Is that normal? I would think they should be open.
Anyhow, got everything torn down to the block and heads. I think I'm gonna change a few things around while I've got everything off both for function and aesthetics.
One thing I would check in ref to the coolant is the water pump seal. If you have a small leak the pressure behind it would spray it everywhere and you won't be able to tell exactly where it came from.
OMG !
thats the source of your next problem ! Glad you caught it.
I can tell you with 100% certainty that stop leak will SEAL off the rear coolant passages in the heads and cause a huge HOT_SPOT that will lead to a warped head or blown head gasket.
I used the stuff 2 yrs ago in an emergency to get home and pulled the left head off that weekend...passages completely closed. We had to chisle our way thru with picks and screw drivers before we could clean it out.
Thats probably whats discolloring the dexcool and messing with the motor,. those rear water passages are the slowest moving of any, so the gunk tends to collect more there than elsewhere. As the engine cools it hardens and you now have no water flow back there.
