DTC 22 - "Throttle Position Low"
Old Apr 9, 2011 | 06:39 PM
97VetteDan's Avatar
97VetteDan
Default DTC 22 - "Throttle Position Low"
I am getting a code of DTC 22 - "Throttle Position Low" when I hook up OBD 1 to my 1990 Corvette. I went out and got a new Throttle Position Sensor and replaced the old one with it. Then I disconnected the battery to reset the codes stored in the computer. I hooked up OBD 1 again and I still got the DTC 22 code. The problem that my car is having is a rapid jerking motion during initial acceleration from a dead stop. When I let the car roll out of a dead stop and then hit the gas there is hardly a problem. Any assistance on this issue would be much appreciated.
Old Apr 9, 2011 | 09:45 PM
OkieC4's Avatar
OkieC4
Code 22 means the TPS circuit is voltage is low.
The TPS is nothing more than a variable resistor which changes by throttle movement.
The TPS gets a 5 volt reference voltage from the ECM on the grey wire Pin C and sends the "adjusted voltage" signal back to the ECM on the dark blue wire (Pin B) to determine fuel delivery.
With a code 21 or 22, the ECM goes to default values to deliver fuel.
With a voltmeter, with key on, backprobe Pins A and B at the TPS and check for .56 volts (+/- .07).
If it is there, open the TB to wide open throttle and look for over 4.5 volts.
If voltage is not there, with the Code 22 history, you may have a wiring problem on the dark blue or grey wires, a bad TPS connector... or no 5V from the ECM.....
Old Apr 11, 2011 | 09:46 PM
97VetteDan's Avatar
97VetteDan
I am only getting .35 volts. I believe the problem to be the ECM. What can be done to get the 5 Volts needed out of the ECM?
Old Apr 11, 2011 | 10:32 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
How did you determine that? You know the TPS is adjustable, right? (At least it is for 89's)
Old Apr 12, 2011 | 12:40 AM
OkieC4's Avatar
OkieC4
My 91 is a non adjustable TPS..
.35 appears low, but before you go for an ecm, I would check voltage at Pin C of the TPS with the key on. It should be 5 VDC.
When you backprobe pins A and B, you are reading the TPS "adjusted" voltage which is being sent back to the ECM.
If you are below .54 while backprobing A & B and you have a known 5 volts coming in to the TPS, then you have a bad new TPS.
If you have less than 5 VDC coming in on Pin C, then you may have a bad or corroded pins at the TPS connector, or high resistance in the grey wire between the ECM and TPS, or dirty/corroded ECM connector pins.
To DTC 22 - "Throttle Position Low"
